P0325 Knock Sensor - Subaru Outback - Subaru Outback Forums
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 4.67 average.
post #1 of 57 (permalink) Old 08-18-2004, 07:23 PM Thread Starter
P0325 Knock Sensor
My 2000 Outback has an error code of P0325. Does anyone have any suggestions on how to fix this? Thanks
jacuze is offline
post #2 of 57 (permalink) Old 09-09-2004, 02:18 AM
Car: '96 Legay Outback
Knock sensor
Hi all,
My '96 2.5l just thru the say code - Knock Sensor.
It's not expensive to replace, but I don't know where it is located!
I have an SVX also, and it's knock sensors are easy to see and get to. They(2 on the 3.3l motor), are on the top of block, under the intake manifold.
Where is the 2.5l motors' knock sensor? Can anyone please tell me?!
Thanks, milehibri - Brian
milehibri is offline
post #3 of 57 (permalink) Old 09-09-2004, 07:53 PM
Knock sensor
FOUND IT!
It is located at the back of the block, drivers side, directly under the accelerator cable/cruise cable/throttle bracket.
The bolt has a 12mm head and is facing directly up at you. The connector is white. Makes it easy to find, once you have the new sensor in your hand.
Hope this is helpful for someone in the future.
By the way, Subaru wants about $55-60 wholesale. But there are other sources available for it. I picked it up for $48.
post #4 of 57 (permalink) Old 11-26-2006, 09:18 PM
Car: 2000 Outback wagon
p0325 knock sensor
Found the info above very useful. unscrewed the sensor, scotch-brited its metal bottom and the spot on the block where it bolts to and torqued it back to ~16ft/lb and the check engine lite went off ! Glad I didn't rush out & buy a new sensor. Hopefully this is a good fix and the problem will stay away a while. If not, thanks all the same.
Dan
kluless is offline
post #5 of 57 (permalink) Old 12-28-2006, 02:36 AM
pipster11's Avatar
Car: 1997 Suby Outback (Manual of course)
top tip there kluless
just did that to my own obw
it was a little lumpy off the pedal after a bit of juice
now its smooth as
pipster11 is offline
post #6 of 57 (permalink) Old 12-31-2006, 03:15 PM
Lord of ScoobyMods
Peaty's Avatar
Car: 16' BRZ Limited / 01' Forester S / 13' OB CVT / 10' Legacy 3.6R / 99 Mita MX-5
http://www.scoobymods.com/forums/showthread.php?t=4039
some KS info for future ref
Cheers,
Peaty
Peaty is offline
post #7 of 57 (permalink) Old 07-11-2008, 02:25 PM
mamurao's Avatar
Car: 1998 subaru outback 2.5, 2 tone green on grey
Send a message via Yahoo to mamurao
Question P0325 code but no check engine light
Hello All,
I just had my car do a random scan on the ODB 2 and a code is stored for P0325 , knock senor malfunction. However I do not see a check engine light,. Last time i had one was when i did not properly tighten the gas cap, after tightening the cap CEL turn off. . Anybody know why i dont have a check engine light on? ,
reply's appreciated
thanks
Theman
mamurao is offline
post #8 of 57 (permalink) Old 07-12-2008, 01:59 AM
ETC
ETC's Avatar
Car: 00 OB 07 OBXT
either your light doesn't work or more likely ....... it's a pending code.
malfunctions need to meet certain criteria before setting a cel/mil. your car will at times set a pending code and if the problem doesn't recur within a specified cycle it will clear it itself.
if it's reading as a set code it should light up on the dash. your scanner should say codes and pending codes.
ETC is offline
post #9 of 57 (permalink) Old 07-12-2008, 06:58 AM
When you start the car see if the CEL illuminates and then goes out. Then you'll know if the light is working.
Blacky is offline
post #10 of 57 (permalink) Old 07-13-2008, 06:42 PM
mamurao's Avatar
confirmed P0325
thanks for the reply all, appreciate the response, today i got a CEL that stayed and same code. Does anybody know where i can get a knock sensor for my sub which is a 98 , I checked with mississauga subaru in toronto and charging me a 220.00 canadian for the sensor, a very expensive one at that. anybody recommend where i can buy one for a bit less.
thanks and i'm looking for the how to's for the replacement of the knock sensor afterwards
thanks
Theman
mamurao is offline
