dtc p1443 - Subaru Outback - Subaru Outback Forums
post #1 of 11 (permalink) Old 07-15-2007, 10:50 PM Thread Starter
Car: 2001 outback l.l. bean
dtc p1443
Hello everyone. I'm a new subaru owner, I've got a 2001 L.L.Bean outback with 54,000 miles which I bought 6 months ago. I really have enjoyed the car,very happy I bought it. I've found this site to be very helpful, but i just can't seem to find an answer to this problem and how to fix it. I have a check engine light and a code P1443 ? Can someone give me some info on this and how to troubleshoot it or at least point me in the right direction? Thanking you in advance. Michael
dupersube is offline
post #2 of 11 (permalink) Old 07-16-2007, 01:10 AM
Car: 97 OB/MT, 01 Fstr/AT, 03 Fstr/MT
Welcome to the forum!
I did a search of the code list I have - got it with the Actron Pocket Code Reader. The P1443 code has the following definition: "Manufacturer Control Auxiliary Emission Controls." Unfortunately, I can find no further explanation for this code.
Can anyone else provide more specifics on this code?
Pete
CO_97 is offline
post #3 of 11 (permalink) Old 07-16-2007, 01:20 AM
Michael,
I've been thinking on this a little more . . . did the CEL come on recently, or has it been on for a while?
One simple thing you can check is your gas cap. I know a loose gas cap will trigger the CEL, but I don't know the specific code.
Pete
CO_97 is offline
post #4 of 11 (permalink) Old 07-16-2007, 12:22 PM
Hokey Pokey Champion
JazzyMT's Avatar
Car: '05 Gold OBXT Stg2+
Guys - there's an ODBII reference list at the top of this forum. For your code - it says:
P1443 EVAP Control System Vent Control Function Problem
From what I can gather in the Subaru tech manual, this vent solenoid is a function of the vapor recovery system that keeps fuel vapors from being discharged to the atmosphere during refueling.
From the sounds of it - it relies on vacuum in the tank to reseal once refueling is complete - that it's not functioning would certainly point to a loose, or uninstalled gas cap as the first source of a problem.
When the Winds of Change blow hard enough, the most trivial of things can turn into deadly projectiles.
JazzyMT is offline
post #5 of 11 (permalink) Old 07-16-2007, 02:36 PM
Thanks, Jazzy. Somehow I missed the OBD-II list . . . yet another great resource at SubaruOutback.org!
Pete
CO_97 is offline
post #6 of 11 (permalink) Old 07-16-2007, 06:45 PM Thread Starter
Smile
Thanks guys, it was the gas cap. Good thing I checked in with the forum before I spent to much time checking all the emission components. Thanks again
Michael
post #7 of 11 (permalink) Old 10-21-2009, 10:51 AM
Car: Former: 2010 & 2002 OB
P1443 CEL Code
Hi all,
My '02 Bean just threw the CEL after a 100 mile trip (no gas fill-up during trip - I ifilled up two days prior). The refernce here says P1143 = "Pressure Sensor Circuit Low Input" and my mechanic cleared the code, but said there was no way to know which pressure sensor it was. Could this be oil pressure? Transmission oil? The EVAP system mentioned in this thread?
I would love to think it was just the gas cap, but that seems like an odd thing to trip the CEL (light was on solid for two days - no blinking). What do you think this is? The car runs perfectly, engine oil is fine, and nothing different from when light came on.
I am about to trade the car in, but don't want any damage if it is a different sensor on a critical part.
Thoughts???
Thanks,
Matt
mattski is offline
post #8 of 11 (permalink) Old 10-21-2009, 11:14 PM Thread Starter
thanks alot for the reply, it was the gas cap.
post #9 of 11 (permalink) Old 09-10-2010, 08:09 PM
Car: '02 OBW 2.5 AT
Send a message via AIM to alexhenryj
I have the P1443 code, gas cap is sealed tightly and I cannot easily put fuel into the gas tank. I have to just barely hold the fuel filler on and slowly fill the tank. I've gone 600 miles with this problem. Where should I start?
alexhenryj is offline
post #10 of 11 (permalink) Old 09-02-2014, 11:12 PM
Car: 2001 Outback LL Bean 3.0L
P1443 Here too
01 Limited Edition with just over 140k on it. CEL with 1443 code.
Seeing here where it is the gas cap. But I also watched this (from this site):
Charcoal Canister Vent Valve Replacement, P1443 - Video
Here it seems (conclusion not clear) that he DID replace the solenoid (the $80 part at the very end). I didn't like how he ohmed it out. He got 2? What's that? I also found this ....
https://www.youtube.com/watch?v=AonEqlN0q1E
Which is for a Forrester, but parts seem the same as in my '01 Outback. He Ohms it out and says it should read 30 to 50 ohms. Well, here's what I did....
Getting the thing off is cake. So I cleaned it carefully before disassembly. Took the solenoid out. Checked the hoses for grime (clean inside). And then checked the resistance of my (bad?) solenoid. 27 ohms, so less than the minimum in second video. I did not have a power probe, so I plugged it back up and energized it with the test circuit enabled. (Green plug underneath driver console right next to center console like in second video).
It sealed well and seemed to cycle fine. So I put it back. Where I am at, part has to be ordered. I cleared the fault code and at this point, I am going to watch and see - get some time on the vehicle. If it's the solenoid, I figure I will get the fault again in a day or two. It MAY be that the cleaning of it and reseating of it fixed it.
If the fault comes back, I will probably check the gas cap first. Figuring transfer blue will let me know if it is not sealing. Then replace this thing second. Will post back with what happened.
Again - this is an easy piece to replace, so no worries. Other than the cost of it.
EDIT - OK, been a couple of weeks now or so, no more CEL. I think mine came on because I topped off the tank and cleaning it well seemed to have fixed it.
Last edited by ncwalker; 09-15-2014 at 11:18 PM. Reason: Status Update after Repair
ncwalker is offline
