Recruit
Car: 2008 Outback
I know it is hotter than blazes, but I have just gotten around to browsing this forum. Maybe someone else has had this problem. I bought my new '08 2.5i OB in December and when it was very cold, the car would start with some hestiation, but I wold lose all of my radio presets. It warmed up shortly after that and the dealer wouldn't look at it since I couldn't replicate the problem and SOA said I would have to wait until this winter to see if it happens again. Should I be worried?
#2 (permalink) | |
Since this should be covered by your warranty, I would take it back and tell them to check the whole system out before the cold weather hits. Or, find a place you trust to check out the system, and show the results to the dealer, and insist that they fix it under warranty if anything is found wrong. |
#3 (permalink) | |
Car: '07 outback basic
As noted, loss of radio presets is characteristic of the memory retention voltage supply to the radio getting too low, typically during a start.
Your Voltage readings are strange. With the engine off, the battery voltage should be around 12.7 V (fully charged). If it's at 14 V, it's way overcharged and there's good reason to suspect the battery condition. However, looking at your other readings, which are unusually high, I would double check the meter you're using. I suspect it isn't reading properly. What type of meter are you using? Also, the battery is connected to the rest of the car circuit by cables. If the cables or connections are bad, the battery voltage can appear to remain fairly good at the battery posts, but at the radio it drops off precipitously when the starter is working because of losses in the cables going to the rest of the car. Turn on the dome light and then start the car. Does the light dim a lot when the starter is cranking, or stay fairly bright. |
#6 (permalink) | |
Thanks for the reply! |
Car: 2007 Outback H6 Bean Edition
I'm having the same problem in an 07 LL Bean. It first happened a few months ago (not even that cold out), and has now happened twice in the last two weeks. Car starts and runs normally, but all radio memory is gone.
I'm curious how many people have found that it ISN'T the battery and that the radio needs to be replaced. |
