Hi- I am looking into having a subwoofer installed in my 2011 Outback and have been wondering whether/how much sound deadening material to use? I have the HK system but want to replace to sub to get more bass. Can anyone who has installed either of these in their outbacks (2010/2011 in particular) please let me know what you did and how much of a difference it made? Thanks!
Car: Black 2010 OB 2.5i Premium CVT
I used 20 Sqft for my doors in total for full outer coverage of doors. Then i used like 15 sqft for the rear where the spare is.
Theres not really going to be much of a difference between them really. They are both brand names. blah...doesnt really matter. I have heard good things about this stuff. Plus...its cheap. or this Edead is also supposed to be good stuff... http://www.edesignaudio.com/product_...roducts_id=786
,Ryan ![]() Upgrades: Primitive light bar and skid plates, Yakima Mega warrior, 18mm RSB , RA mud flaps, Front windows tinted 35% , Subaru bug shield/hood protector, SS damlifier pro , Full LED interior , Phillips HID low beams , Kenwood Exelon DNX-6960 Nav unit, Alpine Type R 17s in front and 17c in back , Kicker 360.4 WANTED: Full interior SS luxury liner pro, Amp and sub, Body side molding. Rolling on Nokian WRG2XL |
Thanks. How long did it take to put it and was it hard for a noob who has never opened a door panel? Did you pull out the speakers to do?
Was there big difference? When do you plan to do the luxryliner from your list of wanted upgrades?
Mods: SubaXtreme Nudge Bar, Hella 4000i Rallye Compact Xenon Driving Lamps (HID), PIAA 1500 H3 55W Back Up Lamps, Primitive Skid Plates, Primitive sub-frame and strut-top spacers, King Springs, GT-Spec Front Strut Brace, B&M Auto Trans SuperCooler #70268 & Trans Temp Gauge, 19mm Sway Bar Kit, NRG Lugs, Hella SuperTone Horns, K&N Air Filter, Fumoto Valve, Escort 9500ci, Osram H7 rallye+65 & Philips HIR1 9011 65W bulbs, clear bra, Dynamat, window tint, full chrome delete |
#4 (permalink) | |
There was a nice difference in the sound of the stereo. Plus no more rattles...A LITTLE in sound deadening...but not much... Now, when putting it on.... there is one thing you dont want to do... You dont want to put the stuff you get on the slider thing for the window... The about the only straight up and down peice you will see in the larger hole. Thats about it. have fun!
If you read about dynamat you only need to use a small amount to get the desired effect, you do not need to coat the entire surface of any part of your car. Read into a little bit. Also the off brand is a lot cheaper then actual dynamat - with a happy an irritated Chip Foose on the box
I don't like this song, I just tap my feet when I get nervous... |
Thanks. I have been researching. I also found this place (Dynamat Kits - Extreme Bulk Dynamat Trunk and Hood Kit) that seems to have reasonable prices on Dynamat but I am still shopping and haven't decided on which brand yet. I also still need to decide if I want to add the equivalent of Dynaliner on top of the Dynamat in each door...
Dynamat used to preach that you only needed a very small amount to do the job, and then they figured out that they should try to get people to cover every surface cause it sells more Dynamat.
They used to have a display with two big coffee cans full of bolts that you could shake and listen to the bolts rattle. One can had about a postage stamp sized piece of Dynamat and the other didn't have any-- the point of the display was that even a little piece of Dynamat was enough to kill vibration and noise. After all, what you're trying to accomplish is killing the metal panel's ability to vibrate, because it's the vibration that transfers sound. Once you add enough Dynamat to stop the vibration (and it doesn't take much) everything else is just added weight. Think about it like this (I play drums) you put your finger on a drum head and that's enough to muffle the sound of the drum. Putting your whole hand on the drum really doesn't do that much more than a single finger.
#8 (permalink) | |
Car: 2013 Outback 3.6 Limited
Had a bit leftover and did part of the spare tire well. Just the spare tire well alone will use a ton. Then if you pull apart the foam inserts it appears there is a lot of bare metal there too. I will probably order another Extreme door kit and use that for the rear cargo area. Interested in any other tips for good sound deadener locations.
------------------------ STI 19MM rear sway bar STI flexible front strut tower brace GT Spec rear strut tower brace LED interior & exterior lights Forester stainless exhaust tips Alpine 235BT Dynamat Xtreme Subtle dead pedal Bosch ICON blades |
#9 (permalink) |
Car: 2012 2.5i Limited
I've used nearly every brand of deadener in some form or fashion in the past and find that reputable brands will all do the same. Raammat, Second Skin, Edead, Fatmat, Dynamat, Roadkill, etc.. will all do the same. In my Accord that I used to compete with I went all out, nearly 400 sq ft covering everything, includind metal behind the dash. The most benefit is obviously the doors and well but I appreciate the roof since it makes most of the noise from rain disappear, and helps tame some of the reflected noise. I would start with 50 to 100 sq ft and cover as much as you can.
#10 (permalink) |
Car: 2004 OBW 2.5 auto
I highly recommend Alphadamp. Good pricing, reputable product, reputable business. I have 20 sq ft in my 2004 Outback and it's excellent. I could do for another 20 sq ft but already the difference is very noticable.
I applied it in the front doors, rear quarters, spare tire well (where the sub is located), and the hatch. -Kevin |
