How to program your Security/Keyless Entry Remotes - Subaru Outback - Subaru Outback Forums
post #1 of 25 (permalink) Old 01-27-2006, 01:14 AM Thread Starter
Programming new remotes
found this page and thought it would be of interest. not sure if it's a repost though
Subaru Remote Programming Instructions (all years and models included):
http://www.cars101.com/subaru/keyless.html
hakamarob is offline
post #2 of 25 (permalink) Old 01-27-2006, 05:23 PM
I'm Not Slash...yet.
FMGreen's Avatar
That is a repost, but it's OK, that's always great info.
I'm going to sticky this topic to the top of the forum because it's a common question.
www.FMGreen.net If you can't keep it clean, keep it green! www.FMGreen.net
FMGreen is offline
post #3 of 25 (permalink) Old 02-21-2006, 07:05 PM
SwitchBack's Avatar
Car: 06 XT LTD 5M - Purchased 8/26/05
One touch opening?
Anyone know if these can be reprogrammed for so that one push opens all doors?
SwitchBack is offline
post #4 of 25 (permalink) Old 02-22-2006, 10:25 AM
westside1975's Avatar
Car: 2004 H6 LL BEANER
Send a message via AIM to westside1975
link appears to be busted, as of 10:25 EST 22 FEB 2006
westside1975 is offline
post #5 of 25 (permalink) Old 06-21-2006, 08:31 AM
Car: 2001 Outback
Unhappy
I also found the link to be dead: "Forbidden
You don't have permission to access /subaru/keyless.html on this server."
Any suggestions for accessing the link?
dhenderson is offline
post #6 of 25 (permalink) Old 06-21-2006, 08:58 AM
FMGreen's Avatar
http://www.cars101.com/subaru/keyles...gram%20remotes
Worked for me...
FMGreen is offline
post #7 of 25 (permalink) Old 06-21-2006, 05:47 PM
Car: 2001 Outback
Thanks FMGreen for the reply
...but the link still doesn't work when I try. C'est la vie. Maybe it's because I'm coming from a server that is considered outside the 'safe zone' -- I'm in the Netherlands, a dangerous place!
post #8 of 25 (permalink) Old 06-21-2006, 06:04 PM
FMGreen's Avatar
"ALPINE SYSTEM, new starting in 1999, used through 2004
Used on:
Legacy, Outback all models 1999-2004
Forester 2001-2004
Impreza 2002-2004
1999 Legacy only: Passive arming of the optional 1999 alarm system.
The dealer could program the alarm to arm automatically whether the doors are locked or not. In this mode the doors must be manually locked or using the power lock button or the remote.
In Passive Mode the system will automatically activate in one minute but will not lock the doors. it will arm the alarm even if the doors are not locked. Lock the doors using the power lock switch with the door open. If you are using the remote to lock the doors, there would be no reason to set Passive Mode because locking with the remote would arm the alarm anyway so I'm not sure why this function exists.... To open the doors use the remote or the key, but then the alarm will go off and you'll need
To set Passive Mode:
Open driver's door and remove the plastic step sill that curves up toward the front.
Connect the single-pole white connectors.
the plain gray buttons were used 99-01, colored buttons for 2002-04
How To Use The Alpine Alarm
Battery #CR2032.
Range? App 50ft. Battery fade, other cars, buildings, walls etc affect range.
1. Locking. Push the large button. This locks all the doors and will set the alarm (if equipped and in setable mode).
2. Unlocking. Push the small button once to unlock the driver's door and disarm alarm, if set. Push the small button a second time to unlock all the doors.
3. Honking horn?
On 1999-2002 models the horn honks once for lock and twice for unlock, 3 times if a door is not closed. This audible honk feature is optional. To turn it off or to turn it on unlock all the doors and hold *both* buttons down until the horn honks once. The horn will always honk 3 times if a door is not fully closed when you lock it.
This was changed in 2003, models to a 'chirp'. There is no longer an audible honk feature. If a door is ajar the system will chirp 5x and the lights flash.
4. Alarm. (optional)
System chirps when locked with the remote if you have an alarm, and no you can't turn the chirp off.
5. Valet mode or alarm off: alarm light (red dot center dashboard display) rapidly flashing 3 times means the alarm is in "Valet" mode and is not setable. The light will stop flashing when you start the car.
To set valet mode or just to disable the security alarm system: 1. unlock all doors 2. physically open the driver's door 3. hold the UNLOCK button on remote for 2+ seconds or so. The red 'security' light will then flash 2 times a second until the car is turned on.
6. Arming the alarm: to make an alarm in valet model arm-able, unlock all the doors and hold the small button down on the remote until the light stops flashing. Now when you lock the doors the alarm will be set and the light will flash on and off, on and off.
7. Alarm goes off?
Push the small button on the remote
OVERRIDING the alarm when you don't have a Remote to disable it.
If you don't have the remote put the key in the ignition and turn it on and off three times and the car will start on the 4th time
8. Program remotes: works on Alpine system.
Unlock all doors. Cycle key quickly but carefully on-off appr 10 times until the car honks one time.
Do not turn the key far enough to start the car, just to the 'on' position so the dashboard lights up.
When the horn honks, open and close the driver's door, press any remote button and that's it.
Program another remote? Quickly open and close the driver's door again and push a button on the 2nd remote. That's it.
When you're done, remove the key and the horn should honk 3 times. You're all set.
Sometime it takes more than 10 on-offs to set program mode. Open/close the door, lock/unlock etc, wait 10 minutes, then try again."
FMGreen is offline
post #9 of 25 (permalink) Old 06-21-2006, 06:20 PM
Car: 2001 Outback
Thanks!
post #10 of 25 (permalink) Old 01-07-2009, 08:48 PM
Car: 08 Outback 2.5i 5-speed
what kind of things can you reprogram the keys to do? (08 OBW)
All Rights Reserved
AKBURU is offline
