Replacing key/fob - Subaru Outback - Subaru Outback Forums
post #1 of 11 (permalink) Old 04-24-2012, 02:10 PM Thread Starter
Car: 16 Limited w/rally bits
Question Replacing key/fob
My 08 Outback came with a spare key/fob... until my wife lost it. A replacement from Subaru is $140, but looking around there are plenty of used keys/fobs on ebay. My question is, as long as the P/N match up- will a pre-cut key, like this one, fit my car? I imagine reprogramming it should be straight forward. TIA..
d
MK19 is offline
post #2 of 11 (permalink) Old 04-24-2012, 02:41 PM
jp1203's Avatar
d
A pre-cut key absolutely will not work. You'd need to find a blank one and cut it, but I've found plenty of blanks on eBay for cheap before.
Reprogramming the remote is typically a DIY thing, but I believe all the 2008 cars have an immobilizer chip, which the dealer would have to program to your car. Most dealers should do this for a lot less than what they would charge for a brand new key/remote.
Current Vehicle:
jp1203 is offline
post #3 of 11 (permalink) Old 04-24-2012, 05:59 PM
lockmedic's Avatar
Car: I has car.
Feedback Score: 3 reviews
Notes I've got say the immobilizer was only on the 2.5XT and 3.0R Outbacks in '08. Can't say for sure but we'd just check the dash for an immobilizer light if the car were here in front of us.
Technically there's a 1 in 7850 chance that key will work your car. Better odds you'll draw four of a kind in 5-card stud poker.
This post may sound self-serving, but check with an automotive locksmith near you. Might be surprised. . . we sell those. You can re-shell a used key but check around to make sure you can get it cut/programmed before buying it. We/most locksmiths/dealers are a bit leery of cutting customer-furnished keys.
An alternative to the dealer is Keylessride:
http://www.keylessride.com/order/quo...&frid=F4A7D33C
$94 brand new, $70 re-shelled (oem guts in a new aftermarket shell that's undiscernable from the OEM one).
We buy from them/refer folks to them without worry. Good folks. eBay: hit and miss.
Ours are about the same price as KR by the time it's cut ($100). . .so not much incentive to buy those from us if it needs to be shipped. I *could* provide it already cut, you'd still need to program the remote tho.
lockmedicben AT gmail
I seem to get a lot of "will xx fit in my car?" emails. . . I'm not the authority on everything Subaru, so I very well may tell you the wrong answer as there's nobody else to check me. Please search or ask via the forums first. . .when I answer you via email, it never gets posted and nobody else can confirm or refute my answer.
lockmedic is offline
post #4 of 11 (permalink) Old 04-24-2012, 06:07 PM
Feedback Score: 6 reviews
And, you really want to have the dealer load up the keyless entry module with both the new and remaining key/fob codes, thereby eliminating/erasing the system's record of the one that was lost.
Otherwise, the lost one could still be used to open/drive the car. If the key was lost near to home, it might be all too easy for someone finding the fob to identify which car it belongs to by pressing the panic or lock/unlock button when near a 08+ Subaru. (The fob and key are together, unlike earlier -- my 07 -- where the fob is separate. Combined key/fob is "driveaway".)
The keyless module can register, I believe, up to four fobs. Two are already in, and there's two spare places. By loading in the two remaining fobs (your original and a new one) twice each, all four places are taken up, and the lost fob's registration is erased (replaced). That way, the lost fob would not be recognized.
(I would add that if was lost nearby, perhaps someone finding it could go around seeing which car responds to the fob and then leave a note for the driver with info as to where the fob can be retrieved. There's still hope . . . )
plain OM is online now
post #5 of 11 (permalink) Old 04-24-2012, 06:33 PM
jp1203's Avatar
Definitely good points. Didn't realize the immobilizer was still absent from the 2.5i in 2008! I was actually shocked that my 2004 didn't have one when I bought it.
I also tend to forget that most people don't have a key duplicator. It's no big deal for me to cut a duplicate of my car key (though if it was chipped I couldn't do anything about that), but I could see where a locksmith wouldn't necessarily want to use a customer's blanks.
Current Vehicle:
jp1203 is offline
post #6 of 11 (permalink) Old 04-24-2012, 06:58 PM
I believe that the immobilizer is standard on all OBs from at least 05. As lockmedic mentioned, it's identified easily by the flashing "security" light on the instrument panel when the car is off, and is described in the Owners Manual (certainly in my 07) without any reference to "if installed" or "optional".
post #7 of 11 (permalink) Old 04-24-2012, 07:02 PM
jp1203's Avatar
Subaru Keyless Entry, Security Alarm, Immobilizer Key, Remote Start Systems. Most years and models
Looks like it was standard on all Outbacks from 2006 on, and for 2005 it was standard on the XT, LL Bean, VDC, and sedan.
Current Vehicle:
jp1203 is offline
post #8 of 11 (permalink) Old 04-25-2012, 08:52 AM
lockmedic's Avatar
Car: I has car.
Models designated for Canada markets got immobilzers earlier than US models. That comes up a lot on the international locksmith forums I'm a member of. Dealer could tell you for sure if its chipped by vin but I don't think a 2.5i will be in 2008. Subaru was pretty lazy when it came to equipping immobilizers.
post #9 of 11 (permalink) Old 11-24-2015, 08:43 AM
Question New chip Key with key code known security Id known
To replace a chip key 2009 outback
Will dealer or ?? be able to duplicate key without digging out the key stashed in the aftermarket remote start bypass? --codes known
Alternative would be to always keep remaining original key inside but not in ignition & use the remote starter key fob for entry . Would this interfere with locking by remote? will try today & repost
Davee3 is offline
post #10 of 11 (permalink) Old 11-26-2015, 10:12 AM
Do I need to go to a dealer What cost is typical
Davee3 is offline
