Journal: Rob's 2013 2.5i Premium Outback in Twilight Blue Metallic - Page 8 - Subaru Outback - Subaru Outback Forums
 1Likes
LinkBack Thread Tools Rating: Thread Rating: 3 votes, 4.67 average.
post #71 of 77 (permalink) Old 04-29-2016, 08:25 AM Thread Starter
AO River's Avatar
Maintenance: Front Brake Pad Replacement at 52,500 Miles, 04/23/2016. Brakes started feeling a little unresponsive so finally changed the OEM factory pads. Replace OEM with Power Stop Z16 Ceramic Brake Pads, a brand I've swapped on a few friend's and family's cars and seemed to work O.K. Plus they're on Amazon, so...
Self-performed, pretty straightforward replacement.
R o b _D.
Current car: 2013 TB/BC Subaru Outback, 2.5i Premium 6mt
Before you start a new thread, please search first! Learn how
AO River is offline
post #72 of 77 (permalink) Old 06-13-2016, 10:48 AM Thread Starter
AO River's Avatar
Maintenance: Oil & Filter Change at 54,500 Miles, 06/11/2016. Self performed, OEM filter and Castrol TWS 0w20.
AO River is offline
post #73 of 77 (permalink) Old 07-21-2016, 03:17 PM Thread Starter
AO River's Avatar
Maintenance: Battery Replacement at 55,525 Miles, 07/12/2016.
R o b _D.
AO River is offline
post #74 of 77 (permalink) Old 11-28-2016, 10:50 AM Thread Starter
AO River's Avatar
Maintenance: Oil Replenishment at 59,000 Miles, 11/16/2016. Oil level light came on while driving home from work so added 1/4 QT Castrol TWS 0w20.
Maintenance: Rear Brake Pad Replacement at 59,950 Miles, 11/23/2016.
Driver side rear brake began making an unpleasant grinding sound at slow speed stops, turns out the rear pad was down to 0% - whoops. For some reason I had it in my mind that I replaced all four corners when in fact I had only replaced the front pads. Replaced OEM with Bosch since they were available locally/immediately. Next brake pad swap I'll probably end up doing all four rotors as well.
Self-performed, easy replacement.
R o b _D.
AO River is offline
post #75 of 77 (permalink) Old 12-20-2016, 08:17 AM Thread Starter
AO River's Avatar
Maintenance: Oil Replenishment at 60,603 Miles, 12/19/2016. Oil level light came on while driving home from work so added 1/4 QT Castrol TWS 0w20.
Modification: Removed winter wheel set and remounted OEM wheels and and tires at 60,590 Miles, 12/16/16.
Current miles on OEM tires: 51,732
Current miles on snow tires: 8,858
R o b _D.
AO River is offline
post #76 of 77 (permalink) Old 12-22-2016, 08:58 AM Thread Starter
AO River's Avatar
Four Year Anniversary
Fourth year of ownership: 60,650 miles on the odometer, 13,978 miles for the year. Lots of maintenance items on order for the 60k service:
P/N - Item
72880AJ00A - cabin air filter
16546AA12A - engine air filter
SOA427V1700 (QTY: 5) - 75W-90 gear oil for transmission/front diff and rear diff
803926090 - gasket for transmission/front diff drain plug
803918060 (QTY: 2) - gasket for rear diff drain/fill plugs
SOA868V9220 (QTY: 2) - brake fluid
86548AJ000 - windshield wiper blade insert
86548AJ050 - windshield wiper blade insert
R o b _D.
AO River is offline
post #77 of 77 (permalink) Old 01-03-2017, 08:56 AM Thread Starter
AO River's Avatar
Maintenance: Front & Rear Differential & Transmission Fluid Replacement at 61,010 Miles, 1/1/2017. Drained the rear differential and front differential/transmission fluid and refilled with OEM Subaru 75w90 gear oil. Lessons learned: change the fluid every 30k miles - both front and rear were black with lots of crap on the drain plugs; the drain and fill plugs on the rear diff on my model (2013 Premium, 6 speed) do not have washers/gaskets - service manual states to use liquid gasket but multiple references stated they have not used a gasket and never had a leak, so giving it a try sans-gasket; use a fluid pump for the front diff/transmission refill - it'll be much faster and cleaner than using a funnel and gravity; service manual states refill capacity for front diff/transmission is 3.5 quarts, but put in 3 quarts and then check the level and add additional fluid as necessary - it's a PITA to drain small amounts if the level is too high.
Maintenance: Engine & Cabin Air Filter Replacement at 61,010 Miles, 1/1/2017. Replaced with OEM filters.
Maintenance: MAF Sensor Clean at 61,010 Miles, 1/1/2017. Performed while waiting for the oil to drain.
Repair: Headlight Bulb Replacement at 61,010 miles, 1/1/2017. Replaced passenger's side low beam bulb with OEM.
R o b _D.
AO River is offline
