Why are my headlights dimming when I hit the brakes? - Subaru Outback - Subaru Outback Forums
post #1 of 14 (permalink) Old 09-09-2009, 03:05 PM Thread Starter
Car: I've owned a 1998 Subaru Outback wagon and I fell in love with it. Now I have a 2001 Legacy wagon that I like even more than the 1st gen Outback.
Has anyone else had the experience of dimming headlights when the brakes are applied? I have a 1998 OBW. It happens every time I hit the brakes, even softly, and it is really quite a dramatic dimming effect. What in the world even causes this? I mean the brakes are hydraulic--why are they sucking a massive amount of power from the electrical system when I use them? Wierd.... Thanks in advance,
Rockworthy
rockworthy is offline
post #2 of 14 (permalink) Old 09-09-2009, 04:01 PM
Tokyo's between my toes
The_Lizard's Avatar
It's a known thing, almost a They All Do That. Snoop around your electrical connections and look for things like corroded terminals, including grounding connections on the body.
The brakes should just draw enough power to activate the brake lights, it wouldn't matter how hard you apply them. Make sure those lights are working OK and there's no goofy incorrect connection like an incorrectly-installed bulb, which can sometimes happen.
Political signatures don't belong on a car board.
The_Lizard is offline
post #3 of 14 (permalink) Old 09-10-2009, 06:38 AM
Car: 2008 Outback 2.5i
It's the brake lights causing the problem, not the brakes themselves.
It's possible the two lighting systems share a common ground or other distribution point. The positive sides should be fed from separate fuses, so from the fuse block on they should be independant.
It's possible your battery or charging system is the culprit. If you can put a voltmeter on the battery terminals and watch the voltage while someone applies the brakes, you should see very little change in voltage (engine running).
Put on one of the overhead dome lights, and see if they dim when you apply the brakes.
Dave Mueller is offline
post #4 of 14 (permalink) Old 09-10-2009, 09:18 AM
8kGoodENuff's Avatar
I have the same problem but it has been like this for 2 years now and the car runs fine. I thought it was something really bad, but it just seems to be normal. I even changed the battery (cause it died on me) and even with the new battery, it still did it. I checked the voltage across the battery terminals and it was to spec.
Other things that I notice as well are that when I turn my headlights on, you can hear a slight change in the rythem of the engine, as if there was a loss of power to the spark plugs or something... I'm still getting great gas mileage though ever since I changed out the Knock Sensor (28 highway / 21 city), so it's running ok.
Andre
2006 Honda S2000 (Good Weather Warrior)
1998 Subaru Legacy Outback (Extreme Weather Warrior)
2012 Subaru Forester 2.5X Premium (Wifey's Ride)
2015 VW GTI S Performance & Lighting Package (Finally Some Torque)
2013 Super Cycles Scooter: 1500-Watt Brushless Motor (702 MPGe... Ohhhh the savings!!)
8kGoodENuff is offline
post #5 of 14 (permalink) Old 09-10-2009, 09:54 AM
Car: 2003 LLBean H6 Outback
Now, if you have ABS, when the ABS works there is a dramatic increase in load on the electrical system.
You'd probably notice the pulsing in the brake pedal, but you could pull out the ABS fuse and see if the dimming decreases, just to make sure there isn't an ABS problem. Unlikely, but possible.
Dave
CNY_Dave is offline
post #6 of 14 (permalink) Old 09-10-2009, 10:19 AM
neutron's Avatar
Car: '11 Outback 3.6R (5EAT)
Clean the battery posts even if they don't look like they need it. When lights dim under a slight increase in electrical load it is a sign of amp starvation.
Corroded lamp terminals could also be the culprit, but not likely in my experience.
neutron is offline
post #7 of 14 (permalink) Old 09-10-2009, 10:52 AM
Hooray's Avatar
Car: 1998 Subaru Legacy Wagon 5 spd
i had a friend who found the continuum transfunctioner to be faulty
it was a $15 part i believe
I yearn for the time when motor sports were dangerous and sex was safe
Hooray is offline
post #8 of 14 (permalink) Old 09-10-2009, 02:30 PM
Car: 2000 OB Wagon
Are you sure it isn't just a misadjusted frammis on the bloviator valve? (I believe you need a left-handed Allen wrench for that)
It's a small world but I wouldn't want to paint it.
SubieNubie is offline
post #9 of 14 (permalink) Old 09-10-2009, 04:43 PM
There was a video supposedly from a big electronics firm like RCA or GE or some other well known name, a guy in a suit talking about their latest product. It was so full of made up parts and technology, I don't know how the guy got through it with a straight face. Funny stuff if you're in the business.
[edit] Here it is:
http://www.youtube.com/watch?v=RXJKdh1KZ0w
post #10 of 14 (permalink) Old 09-11-2009, 08:49 AM
check batter terminals, and grounds
arthuruscg is offline
