Interior light anomalies - Subaru Outback - Subaru Outback Forums
post #1 of 3 (permalink) Old 01-02-2010, 04:07 PM Thread Starter
Car: outback 2005
On cold evening yesterday, interior light on right front passenger door did not turn off when door was closed. Dashboard indicator showed right front door open, although door was shut and locked. After several tries of shutting door and pressing in black "nipple" button on door frame (which controls the door light operation), the door light and dashboard indicator light went off. But problem has returned today. We don't want light to stay on and run down battery. Any suggestions (besides simply removing lightbulb)? Perhaps coincidentally, the alarm went off two times (inexplicably) after we thought we had corrected the problem. We turned off the alarm using the unlock function on the remote entry.
michelndu is offline
post #2 of 3 (permalink) Old 01-02-2010, 07:15 PM
Feedback Score: 6 reviews
Probably some water or condensation got into the switch behind the rubber cover, and it being very cold, has frozen a bit so that the switch. If the car is parked in a warm garage, the water might dry out. It might be possible to lift the rubber cover off and use a hair dryer to speed up the drying.
Check that the rubber cover is on properly and there's no tears in it that allow water to enter.
To protect the battery, the ceiling light can be switched off (the switch has three positions, ON, DOOR, and OFF) however, the dash warning light cannot be easily defeated. This is an LED and shouldn't drain the battery unless it is already quite run down and there are no other lights on.
The alarm is sounding because it senses a door open when it shouldn't be (e.g. the car has been locked)
plain OM is online now
post #3 of 3 (permalink) Old 01-03-2010, 06:21 PM
Banned
hunterlord's Avatar
Car: 2005outback 2.5i
tape is to tight
i had the same thing happen seems like when the wire harnesses are made they are using black electrical tape to manage the bundles. even at the flex points around the doors and rear hatch (this is where i found my problem) the tape is not letting the wires flex. i have found broken wires and stressed insulation due to this flaw.
hunterlord is offline
