Car: 2005 OBW 2.5i, snorkel, skid plates, etc...
Just finished the DDM Tuning fog light upgrade.
It is a true plug and play setup at a price that can't be beat. Went with the 35W 3000k set and am very pleased with the light dispersion and pattern. Checked it on the road and driving towards it in another vehicle and there is no issue with blinding/annoying oncoming traffic as the spread is low and wide. And since one of my low beams bought the farm this week, I'm going to fit the DDM H7 35W 4500k kit in the low beam projectors. Will try to get pics up tomorrow.
SOLD 05 Subaru Outback 03 Chevy Suburban SOLD 95 Audi S6 "99% of being smart is knowing what you're dumb at..." The Superu
#2 (permalink) | |
I have been thinking through how I will hook up the DDM kit for the headlight, given the nature of the waterproof housing, so I will be interested to see what you come up with too (although it may be different on the 3rd gen). BTW, how did you settle on the DDM kit?
You guys remember this thread, right?
~Scott '05 Outback 2.5i Wagon Willow Green Opal/ Moss Green Metallic '04 KYB's all around | SpecB LCA Bushings | Whiteline Rear Camber Bushings | LGT RSB | Hawk HPS Pads | Nokian WR G2 SUV's | '08 HU | Subaru Sub Save The Manuals!
#4 (permalink) | |
#5 (permalink) | |
I learned something a long time ago about the - flood lighting for short distance sides of the road ie under the bumper lights.
1st off they are not "fog lights" the true purpose of the smaller under bumper lights which you can turn off and on with (Low Beams Only!! State law in nearly every state) is for lighting the sides of the road at short distances vs the long distance head lights. Check to make sure when you hit your high beams that the flood lighting under your bumper turns off automatically. The lighting concept is actually from the rally car world where you need both long distance visibility and some flood lighting along the shoulders of the road at short distances so you can see where the shoulders of the road are and any items that might damage your car etc. Lighting in fog - the lower angle and more specific ie targeted beam of light creates less reflection off the fog and better visibility your low beams are the best option- something that true rally style running lights are not good for given they are more of a wide flood style light source thus creating more reflected light off the fog if used. Don't confuse our clear bright white flood style running lights with the old yellow lensed days of the past "fog" lights. They are not the same and have two totally different applications and functions. I use my under bumper flood lighting for reading street signs in dark locations - and when driving on narrow dark roads with sketchy shoulders they dramatically improve your short range road shoulder visibility. Hence why they are located as far outboard as possible and generally light up an area quite close to the car with a broad flood style range vs a very specific beam of light. |
Banned
Car: 2005outback 2.5i
somebody on here in a past thread reminded us about rod and cones. during long drives in unlit rural areas my eyes don't fatigue. i can go 400 miles at night without that burning eye feel.
#8 (permalink) |
snowbaru?
Car: 99 Outback Limited, KN Filter, tow hitch, black tint, Hella 500s, DIY clear corners
i noticed they (DDM Tuning) have a set for 35W 9007 Hi/Low bulb. How do you think they would work in a 1st Gen OBW?
The best mod is one that you do yourself and no one else has |
#10 (permalink) |
Just installed a set of 4500k H7 HIDs in my 05.
Will try to get better pics once the rain stops, but here's a cell phone shot to start you off. ![]() The kits are both from DDMTuning. They are the 29.95 Apexcones. 3000k for the fogs. True PnP with no cutting or drilling required. 4500k for the lows. No cutting, but need to drill a 7/8" hole in the middle of the cover to feed the wires through to the ballast. Grommet included works fine. The projector lamps still maintain the cutoff and appear to offer a good pattern. I also did the 5 minute DRL mod to eliminate those while I was at it. The fogs have been fantastic in the rain over the past few nights. Very easy on the eyes when driving on unlit forested roads. Will post impressions of the 4500k lows after I've had a couple of nights behind the wheel with them.
