Taillight bulb replacement? - Subaru Outback - Subaru Outback Forums
post #1 of 12 (permalink) Old 03-22-2010, 09:20 PM Thread Starter
Car: 2001 Outback, EJ25, 5mt
Anybody have the directions for replacing taillight light bulbs in a 2001 Subaru Outback?
gryffinwings is offline
post #2 of 12 (permalink) Old 03-23-2010, 12:44 AM
Car: 2002 Outback
The stop/brake/park and blinker bulbs in the quarter panel?
* Open the boot/trunk, pop off the 2 covers (#16/17 and 19/20 in this picture http://opposedforces.com/parts/legac...llustration_3/).
* Get a 8mm deep socket and undo the 2 nuts - they are on studs and they are about 10mm long - DO NOT drop the nuts, you will more than likely not get them back.
* From the outside of the car, tap the tail light with the palm of your hand backwards - it is held in by a locating clip and "pops" out.
* Undo the 2 phillip's head screws on the harness holder/finisher.
* Take out the bulbs and the lens comes free.
Stuff goes here.
bobbyjimmy is offline
post #3 of 12 (permalink) Old 03-26-2010, 11:33 AM
goldcrown4's Avatar
Car: 2001 Outback Limited 4cyl
Send a message via Yahoo to goldcrown4
I just replaced a dim bulb because it wouldn't light up anywhere near bright enough when pressing brake pedal. This was done on the rear driver's side (#1157 I think) in my '01 Ltd OBW... my rear lift gate has small hand-sized access panels. I opened it, push-n-turn bulb to remove, push-n-turn replacement bulb. Ops Check Good.
There is real magic in enthusiasm. It spells the difference between mediocrity and accomplishment.
-- Norman Vincent Peale
goldcrown4 is offline
post #4 of 12 (permalink) Old 04-21-2010, 05:09 PM
Car: '01 OBW base model w/AT
Better (brighter!) replacement bulbs are what I want. Anyone?
I've disabled DRL on my 2001 OB and during the daytime I drive with the lights "half" on (just the parking lights I guess).
I've found a few threads dealing with headlights/foglight alternatives but can't seem to find much on taillights, brakelights, reverse lights etc....
Pleiades is offline
post #5 of 12 (permalink) Old 04-21-2010, 10:50 PM
morganluke's Avatar
Car: MY02 Subaru Outback
Unless the bulb in the tailights have burnt out, they will all be the same brightness. A bulb is a bulb. Headlights are completely different so you can get brighter ones.
You can get LED replacements but because of the difference in current, you will need resistors to stop the blinkers from blinking fast (they think a globe is out becuase of the low current of the LEDs).
morganluke is offline
post #6 of 12 (permalink) Old 04-21-2010, 11:24 PM
Dang! One of the few 'upgrades' I might afford..... I was hoping to find some standard bulbs with a bit higher wattage to make them more noticeable during the daytime in particular. Out of luck?
Having said that, I can't even find the bulb types (numbers) for all these parking, tail, reverse, tag lights so I wouldn't know what to order even if it were available....
Pleiades is offline
post #7 of 12 (permalink) Old 04-21-2010, 11:53 PM
morganluke's Avatar
They are just plain halogen bulbs. The reverse ones are slightly smaller from memory. There just isnt much point changing globes unless they are busted.
Changing parkers however, is something different. Ive got some white LEDs heading my direction as i type. Especially with HID headlights they change the look of the front of the car nicely - unless you replace with coloured ones which is for Honda Civics with ironing boards on teh back...
Dont be disheartened! ...there are plenty of other small mods you can do which are affordable.
post #8 of 12 (permalink) Old 04-22-2010, 08:45 AM
bigdadi's Avatar
Originally Posted by Pleiades View Post
.... I can't even find the bulb types (numbers) for all these parking, tail, reverse, tag lights so I wouldn't know what to order even if it were available....
Automobile light replacement guide ...
OSRAM SYLVANIA - Replacement Guide - Start
bigdadi is offline
post #9 of 12 (permalink) Old 04-22-2010, 09:21 AM
miker104's Avatar
Car: 1999 30th Anniversary Legacy Outback DOHC 2.5L 4EAT, 1998 Legacy Outback DOHC 2.5L 4EAT, 2003 Forester 2.5X 5MT
Even Closer:
http://www.sylvania.com/ConsumerProd...RG-Results.htm
I have bought LED Bulbs from here:
Super Bright LEDs - Brake Light, Turn Light and Tail Light Bulbs
You will need a replacement flasher for the Turn Signals with LED bulbs to keep the flash rate normal.
miker104 is offline
post #10 of 12 (permalink) Old 04-22-2010, 09:46 AM
Thanks, I printed out that sylvania list.
Pleiades is offline
