VDC valve relay: where is it? - Subaru Outback - Subaru Outback Forums
Old 02-16-2011, 03:34 AM   #1 (permalink)
KorsH's Avatar
Car: OBW '03 H6 VDC Euro
Default VDC valve relay: where is it?
Good day!
I've recently had ABS/VDC warning icons lit up on my OBW '03MY. Controller diagnostic indicated an error code 51. Which, in turn, leads us to possible faulty VDC/ABS valve relay, but I'm confused where I can find this relay? Should I search the main relay box under the hood for it?
Thanks in advance!
"Subie, Subie über alles!"
My profiles on:LinkedIn|Facebook
KorsH is offline   Reply With Quote
Old 02-16-2011, 05:47 PM   #2 (permalink)
Car: 1998 subaru outback - some dents and scratches, no rust. Good car to build on
relay info
ABS light and noise please HELP - NASIOC
1998 Subaru Legacy Outback
Engine Rebuilt!! Lets Go!!
Typhoonk is offline   Reply With Quote
Old 02-17-2011, 02:18 PM   #3 (permalink)
KorsH's Avatar
Originally Posted by Typhoonk View Post
relay info
Thanks for reply, but it's slightly different info than I need. The question stays on
Old 02-17-2011, 03:44 PM   #4 (permalink)
Car: 2003 LLBean H6 Outback
I can only find reference that it's in 'the relay box', I assume that's the main relay box.
There's a 'valve relay' and a 'motor relay'
Dave
Old 02-17-2011, 04:12 PM   #5 (permalink)
KorsH's Avatar
Thanks for your suggestion, Dave. I've got main fuse box inspected with no result. There are mostly fan, a/c and headlight relays. I found no VDC/ABS relays among them.
Where should I search next? Under the dashboard?
Looking through service manual isn't getting me any anywhere - I simply can't find any reference about this "the relay box" location...
Old 02-17-2011, 04:24 PM   #6 (permalink)
If there's not a special VDC relay box under the hood, yeah, I'd try under the dash.
Maybe there's a relay box attached to the VDC control unit?
Dave
Old 02-17-2011, 07:01 PM   #7 (permalink)
Dave is probably on the right track.
The 2003 VDC wiring diagram shows two connectors, F89 and F90 that are related to the relays. In the Front Wiring Harness diagram, these connectors are where the ABS/VDC unit is located, that is, engine compartment, right front fender. That would suggest the relays are next to, if not inside, the ABS/VDC unit.
Old 02-22-2011, 06:08 AM   #8 (permalink)
KorsH's Avatar
Thanks for your info, guys! Unfortunately due to somewhat cold weather I've had to put off my investigation =)
