Hi there!
I was shopping earlier this week, and opened the driver's side back door when the alarm went off. What? Turns out that I forgot to unlock it first, and the door wasn't actually locked. The power door lock on that door failed.
I took the door apart this morning. At first I was hoping it was just a wiring fault, but a quick check with a meter said the wiring was fine. The shop manual has some scary language about removing the door latch/lock module involving removing the door glass, etc. but that's not necessary. Remove three screws and the latch assembly comes out enough to access the door lock actuator.
Remove the cover, and one screw, and the door lock actuator comes off. It's sealed, but I figured I didn't have anything to lose so I pried it apart.
The motor itself had some surface rust on the motor case. I lifted the motor out, and the shaft was stuck. Some cleaning fixed that. I cleaned and re-lubed the assembly, and reassembled the case. I put a few drops of super glue on the seam to hold it together, and sealed the seam with some automotive strip caulk. That seems to have fixed it.
One note -- be careful reinstalling the door lock motor, as there is a tab that fits around the door latch module that can break. I managed to do just that, but I was able to glue it back together.
