2002/3 Climate Control Aspiration Tube - Subaru Outback - Subaru Outback Forums
Old 07-15-2012, 09:02 AM   #1 (permalink)
Doctor Shifty's Avatar
Car: 2003 Outback. 2.5
Default 2002/3 Climate Control Aspiration Tube
I recently had an audio shop install a new double din CD unit. Since then the climate control does not work as it should, it gives me too hot or too cold with no intermediate area.
With a bit of websearch I found others with this problem. It seems that the aspiration tube that sucks air past the temp sensor is unattached.
By lying under the steering wheel with my head resting on the pedals I can see a white plastic flexible tube with both ends open. One end is attached to the heater body in what seems to be a venturi arrangement. The other end is just lying there unattached.
Is this the aspiration tube?
http://www.kimmiller.id.au
Doctor Shifty is offline   Reply With Quote
