ball joint removal - Subaru Outback - Subaru Outback Forums
post #1 of 7 (permalink) Old 06-14-2008, 10:10 AM Thread Starter
Car: 97 2.5 mt outback 98 forester s
ball joint removal
so how do you all get the ball joints out? tired and need to get done. thank you.
cleansubaru is offline
post #2 of 7 (permalink) Old 06-14-2008, 01:13 PM
Car: 2001 Outback, EJ25, 5mt
Re: ball joint removal
Those ball joints in the lower control arms, are a pain to get out, unless your superman, your going to need to get them pressed out, which is what I had to do, install was a breeze, because for some reason they don't press in, well mine didn't anyways.
gryffinwings is offline
post #3 of 7 (permalink) Old 06-14-2008, 02:56 PM
lomita's Avatar
Ball Joint Removal
Per our Subaru manual:
1) Remove the wheels.
2) Pull out the cotter pin from the ball stud, remove
the castle nut, and extract the ball stud from the
transverse link.
3) Remove the bolt securing the ball joint to the
housing.
4) Extract the ball joint from the housing.
Ours practically fell out. We did step three and four first and pulled down on the control arm to pull it out of the housing.
Try wetting it down with some Marvel Mystery Oil if it is stuck. If you leave the bolt in the housing, the ball joint will not come out.
Which end is stuck in your situation, top or bottom?
lomita is offline
post #4 of 7 (permalink) Old 06-14-2008, 03:53 PM
Re: Ball Joint Removal
transverse link.
housing.
Ours practically fell out. We did step three and four first and pulled down on the control arm. to pull it out of the housing.
Your's just fell out, must be nice, mine was a PITA, had to get it pressed out, sounded like a gun shot when it finally came out. But maybe sometimes that's the only way, if it's never been replaced, like mine which had been flattened.
post #5 of 7 (permalink) Old 06-15-2008, 12:02 AM
Flyboy_2404's Avatar
Car: 1996 Legacy Outback. 2.5 L
I Just did mine per the instruction manual, but I ended up having to pop them off with a pickle fork. If you're planing on replacing the ball joints, don't worry about damaging them, just use a pickle fork.
I Love My Car
Flyboy_2404 is offline
post #6 of 7 (permalink) Old 06-17-2008, 01:56 AM
Banned
karpiel666's Avatar
Car: 98 OB LTD.
After I bent my 4 foot cheater bar and snapped my pickle fork I decided to take the steering knuckle to a shop. 10 minutes and 10$ later it was out.
karpiel666 is offline
post #7 of 7 (permalink) Old 06-20-2008, 04:53 PM Thread Starter
hi. thank you for help. got a pitman arm remover for control arm side. then used a pickle fork at various angles to shimmy it out of the knukle. didn't take to long once i got the pickle fork.
