Spare tire - size - Subaru Outback - Subaru Outback Forums
post #1 of 7 (permalink) Old 11-04-2008, 12:56 PM Thread Starter
eugenelt's Avatar
Car: Outback 2.5 2004
Spare tire - size
Hi
I've just noticed that my spare tire is of 145-80-16 size, which is over 5% difference from my stocks.
Does that mean I'm likely to kill my transmission if I try to use them ?
eugenelt is offline
post #2 of 7 (permalink) Old 11-04-2008, 07:59 PM
Feedback Score: 6 reviews
I believe that's a "donut"type of spare tire. They are typically smaller in overall size and circumference than the stock wheels and tires.
Check your Owner’s Manual. It should list the size of the spare for your car. If it is the same as the one you have, and the other tires are also the size specified in the manual, then, if you follow the Manual’s instructions when using the spare -- especially limiting the driving speed and distance – there shouldn’t be a problem.
Your concern, however, is well founded. If one of the four wheels is an odd size, the front and rear drive shafts will turn at different speeds. This could put extra strain and wear on the transfer clutch (automatic transmission) or viscose limited slip center differential (manual transmission). But both systems are designed to accommodate some difference over a short term, otherwise turning a corner would be a problem. Consequently when using the spare, speed should be kept low, and the overall distance should be limited.
Some have bought a full size spare to avoid the risk, although, if the spare is not included in the regular rotation of the wheels (5-way rotation) then wear of the four working tires will eventually leave the spare somewhat larger than the others, and the same concern arises (although the difference might not be as great). From what I've read here, I believe the spare tire well in the 05+ models is barely large enough, if that, to hold a full size tire and wheel at the proper inflation.
plain OM is offline
post #3 of 7 (permalink) Old 11-05-2008, 09:37 AM Thread Starter
eugenelt's Avatar
Yeah, it's a donut.
Went with a smaller winter tires to have a better match to a spare..
Subaru should do a better job matching spare to stock tires, though.
eugenelt is offline
post #4 of 7 (permalink) Old 11-05-2008, 01:40 PM
dhintonca's Avatar
Car: 09 Outback PZEV, H4, 4EAT
Re: Spare tire - size
Originally posted by eugenelt
Hi
If I recall correctly, the owner's book says to pull the fuse when you use the spare (puts the car into FWD mode). Presumably this reduces the risk of damaging the transmission.
Cheers, Dallas
2009 Outback PZEV (Raised 2.5 inch)
1984 Chev/Frontier Class C Motorhome
2002 Impreza RS 2.5 (gone)
1976 Dodge Kary Van (gone)
1969 Ford Cortina GT (gone)
1967 Sunbeam Arrow (gone)
1967 Hillman Minx (gone as of 2005)
dhintonca is offline
post #5 of 7 (permalink) Old 11-05-2008, 02:51 PM
Re: Re: Spare tire - size
Actually you disable it by putting a fuse in.
No roads?
No problem.
Subaru
Jafaro is offline
post #6 of 7 (permalink) Old 11-05-2008, 03:26 PM
dhintonca's Avatar
Re: Re: Re: Spare tire - size
Oops -- you're right! :-)
Cheers, Dallas
post #7 of 7 (permalink) Old 11-05-2008, 06:03 PM
"If I recall correctly, the owner's book says to pull the fuse when you use the spare (puts the car into FWD mode). Presumably this reduces the risk of damaging the transmission."
Woops. I completely forgot about that. Should have looked in my Owners Manual when drafting.
Thanks for the clarification.
plain OM is offline
