LinkBack | Thread Tools |
Rating:
#11 (permalink) | |
#12 (permalink) | |
Flying Cavalry
![]() ![]() Join Date: Feb 2009
Car: 1997 Subaru Outback Wagon 2.5, Manual 5 speed
I prefer to have a rake (rear higher than front) or level look. Looks like I might have to go aftermarket for a lift. |
#13 (permalink) | |
#14 (permalink) | |
Flying Cavalry
Just went to Rallitek's site, they have nothing to lift my old Outback. So I looked at Forrester lift, since I figured if Forrester parts fit our Outback, Forrester aftermarket will fit ours too, but there was no lift kit there. Search continues.. |
#15 (permalink) |
Two things:
To find out if Rallitek made anything for my Gen. 1, I had to call and talk to them directly. None of the products were listed on their website. Try giving them a ring. They're really friendly. The stock stance for a Gen. 1 is lower in the front than the back, so I don't think it will set it back after the above described lift. This is what I estimate solely on the measurements already talked about. STL97, I do see a slight setback on the Team Illuminata car, and I wonder if there is a way to raise the rear a little more or lower the front by a half inch to an inch. Maybe by using forester strut mounts instead of outback ones or visa versa. Are there spacers that can go between the rear mounts and the body of the car? Is that even a possibility? |
#16 (permalink) |
I think its getting too late for me or the head cold is really getting to me.
They say that the Forester rears will raise the rear 1". The other posts say that the Rallitek Springs will raise the rear atleast 1.5". That is much better than the Forester rears in my own head because the HD springs won't compress as easily as the Forester springs, keeping the stance in the back more constant. Also, the difference in lift is around 0.5". Pretty negligible. |
#17 (permalink) | |
Any hints as to a good place to find Forester fronts all assembled, new? Or a good place for KYB GR-2's? Thanks
#18 (permalink) | |
http://shop.ebay.com/items/_W0QQ_nkw...Q_fromZQQ_mdoZ This was just the first place I looked, you might be able to find these cheaper elsewhere. 108 a piece for fully assembly Forester front strut assemblies. http://www.trademotion.com/partlocat...layCatalogid=0
#19 (permalink) | |
Cool, thanks. I saw those earlier. That's not too bad. $216 for the front. The cheapest rear GR-2's on ebay are about $60 each and the HD springs are $148, so we're talking $270 for the rear. Total at $486 + shipping and we're over $500 give or take a little depending on where you get those fronts. Hmmm.... (grinning and scratching chin) |
#20 (permalink) | |
Flying Cavalry
DO IT DO IT DO IT So that I can see the measurements on how much your car gets a lift, and how it looks, before I pull the trigger.
