Order of air bleeding? - Subaru Outback - Subaru Outback Forums
post #1 of 9 (permalink) Old 03-18-2010, 02:21 PM Thread Starter
Car: 2001 Outback
Hi -
I've got a 2001 Outback, and I'm wondering: is there a specific order in which you bleed the brakes? Thanks in advance!
Fuzz72 is offline
post #2 of 9 (permalink) Old 03-18-2010, 02:43 PM
miker104's Avatar
Car: 1999 30th Anniversary Legacy Outback DOHC 2.5L 4EAT, 1998 Legacy Outback DOHC 2.5L 4EAT, 2003 Forester 2.5X 5MT
I think it has ABS Brakes?
The order is closest wheel to ABS unit first. From the 2000+ FSM:
Brake fluid replacement sequence; (A) Front
right → (B) Rear left → (C) Front left → (D) Rear
right
miker104 is offline
post #3 of 9 (permalink) Old 03-18-2010, 03:09 PM Thread Starter
Car: 2001 Outback
What I just found in the service manual agrees with your reply. Thank you!
Anybody know if there are special issues with the process of bleeding brakes on a car with ABS? Anything extra that needs to be done?
Fuzz72 is offline
post #4 of 9 (permalink) Old 03-18-2010, 10:10 PM
driveby's Avatar
Car: 2001 OBW H6 VDC
Yes. You should run "sequence control" on the ABS system to remove any air from the ABS hydraulic unit.
You can run sequence control by grounding two contacts in the diagnostic connector in the driver's footwell, turning the ignition switch on, and holding the brake pedal down immediately after the abs light goes out.
Consult your service manual for complete details on the connector and sequence.
-Jeff
driveby is offline
post #5 of 9 (permalink) Old 03-19-2010, 12:13 PM Thread Starter
Car: 2001 Outback
-Jeff
Thanks so much for the information! When in the brake bleeding process should I run the sequence control? Also, any idea where in the service manual this info is? I have .pdf files of the manual, and they are in no particular order...
Fuzz72 is offline
post #6 of 9 (permalink) Old 05-11-2010, 07:18 PM
Car: '05 Subaru Legacy GT, '99 Outback
The manual says 4-4 (W15DO) for the perform sequence control, however I can't find that particular W15DO in the manual...
sspeed is offline
post #7 of 9 (permalink) Old 05-11-2010, 08:17 PM
Ok, here's a dumb question.. how do you know when "sequence control" is done? I jumpered 3 and 6 on the diagnostic connector and pressed the brake pedal within .5 seconds of the ABS light going out, then what? The manual simply says, "After completion of ABS sequence control, turn ignition switch OFF." I sat there with the brake pedal down for about 30 seconds watching, listening, and waiting, nothing seemed to happen?
sspeed is offline
post #8 of 9 (permalink) Old 05-11-2010, 09:45 PM
tigerclaws's Avatar
Car: 2005 OB 2.5i AT
right
This would be such a pain in the butt to follow (if u were using jack stands at home really). Ideally in my Hondas I do the rears first followed by the fronts.
tigerclaws is offline
post #9 of 9 (permalink) Old 05-27-2010, 06:10 PM
satan's Avatar
Car: 1996 Legacy Outback Wagon 2.2L 5-sp
Did you jumper them together only ? They both should be grounded (and you relly need to mash on the pedal - the pressure you're creating is supposed to do the work. you'll feel it in process.
satan is offline
