Rear 05' Legacy GT sway bar on an 08' Outback???? - Subaru Outback - Subaru Outback Forums
Old 09-08-2010, 08:48 AM   #1 (permalink)
Car: 08' Outback Limited
Default Rear 05' Legacy GT sway bar on an 08' Outback????
Any suspension gurus out there know if this would fit and if it would be an upgrade?
Farnsrocket is offline   Reply With Quote
Old 11-30-2012, 10:46 AM   #2 (permalink)
Heffernan's Avatar
Car: 2008 Subaru Outback 2.5i 5spd
Bumping this as I'm thinking about doing the same mod if its worth it.
King | KYB | Whiteline | Subtle | Yokohama | OEM+ | Yakima
Heffernan is offline   Reply With Quote
Old 11-30-2012, 01:32 PM   #3 (permalink)
Car: 2005 Outback Sedan 3.0R
I'm sure this won't be much help but I put an '05 Legacy GT sway bar on my '05 OBS and it fit fine. But, there was maybe a 10% - 15% difference in feel even with the AVO sway bar reinforcement braces and new bushings that I added at the same time. If I were to do it again I would probably go with a 19mm bar instead of a 16mm bar.
Soledad is offline   Reply With Quote
Old 11-30-2012, 02:50 PM   #4 (permalink)
Seabass's Avatar
Car: 05 OBXT 5eat stg1.2
It should fit fine, but it's not much of an upgrade if you're talking oem swap. I think it's 15mm instead of 13mm. If it's aftermarket, then the fitment is the same between LGT and OB.
Old 11-30-2012, 03:11 PM   #5 (permalink)
Heffernan's Avatar
Would going with the LGT bar require the AVO brackets? Or is it too small of a difference that they wouldnt be needed?
Old 11-30-2012, 03:28 PM   #6 (permalink)
rasterman's Avatar
Car: 2006 Outback XT Limited
You shouldn't need the AVO kit. If anything it is a simpler swap without.
Mind you it's a nice bracket set, I like mine. I don't think it changed the feel at all, but it gives me peace of mind.
Old 11-30-2012, 03:36 PM   #7 (permalink)
Heffernan's Avatar
What I meant to say was would adding the slightly larger LGT RSB warrant any concern of the stock OB mounts to bend, like we have seen from thicker RSBs. Or is the difference between the LGT and stock OB bar not significant enough to worry about having the stock mounts bending.
Old 12-01-2012, 03:55 AM   #8 (permalink)
Seabass's Avatar
The lgt bar shouldnt require aftermarket mounts, but consider what happens if the stockers break. They dont just bend, they like to snap off. Then you have to break out a welder to fix it.
Old 12-01-2012, 10:29 AM   #9 (permalink)
Heffernan's Avatar
Right. I guess if I would need the AVO brackets it wouldn't be worth adding a LGT bar. It should like I should just consider going aftermarket at that point.
Old 12-03-2012, 10:03 PM   #10 (permalink)
Car: 09 OBW base => 07 OBXT LTD 5sp
Default RSB options
I can't remember where I saw it, but I think some LGT wagons have an 18mm solid rear bar (maybe EDM??? but maybe USDM). Someone once remarked that the worshipped JDM hollow 20mm had basically the same effect. USDM LGT sedans probably have the 16mm bar, and then us lowly USDMOB owners got the 15mm.
Impatient is offline   Reply With Quote
