Can you tow an AWD Subaru on a car dolly behind a RV, should the front or rear end be on the car dolly ?
you could disconnect the drive shafts.I've towed 3 outback with AT's home with the front wheels on a tow dolly in the past month or so, and did no damage to the transmissions. Each one was about 70 miles. I expected to toast the transmissions, but I didn't care because I just wanted the engines. In your case, I might try removing the front axles, and putting the rear wheels on the dolly. I read a post here about using a switch to lock the tranny somehow so you'd have locked rear wheel drive. The hot rodders do it. Check with idosubaru. Backwards steering geometry might not work right on the dolly. In my case, I tow my 5 sp impreza to deliver trucks, but driving it all day gives me a backache, and now I have a couple extra outbacks with AT's and electric seats, and would like to figure out a way to flat tow (4 wheels down) them. I asked a similar question under towing, and I can't find it right now, but someone mentioned the possibility of an external oil pump. I am wondering if you'd stop every 50 or 100 miles, start it up and let the tranny oil circulate for a few minutes; maybe get a trans oil temp gauge. I might try it. Let me know how you make out.
