Subaru TPMS cloning - Orange Electronics sensors
68K views 46 replies 20 participants last post by  Fibber2
Here is a little primer I put together about the Subaru TPMS system and how to clone TPMS sensors for a set of winter wheels without having to do TPMS resets each time the wheels are swapped.
I have two Subarus, my wife's 2007 Outback and my 2009 Forester. This past year I picked up sets of winter wheels for both cars and wanted to explore if I should get TPMS sensors put in them. Last winter I ran my winter wheels without TPMS and just ignored the warning light. I wasn't keen on telling my wife to just ignore the light on the dash, so I did some research on what was possible.
If you run a set of winter wheels, a few states require working TPMS sensors to pass inspection, but most do not. TireRack has a good summary: http://www.tirerack.com/wheels/tech/techpage.jsp?techid=214
Subaru uses two different TPMS sensors, depending on the year of your car. Generally, for 2004-2007 vehicles they use OEM Part # 28103AG00A which operates on 315 mhz, and 2008+ vehicles use OEM Part # 28103AG01C which operates on 315 mhz. Each sensor has a unique ID that it transmits every few seconds when it is in motion, along with the tire pressure reading and battery life remaining.
The TPMS module in the car is programmed to receive this data from the four TPMS sensors IDs it is linked up to. The Subaru TPMS module is a simple one that only displays a warning light on the dash for a TPMS fault, but does not display tire location nor pressure like some other car manufacturers.
A TPMS fault is triggered either by a tire whose pressure has dropped under about 26 psi, a TPMS sensor that has a low battery warning of less than 10% life left, or the absence of data from a sensor, such as when one dies or all are missing, like if you were using a separate set of winter wheels without sensors.
If a TPMS sensor in a wheel is changed, the module would have to be reset to relearn the ID of all the sensors on the car. Until recently, the TPMS sensors have been fixed with their IDs, which made it difficult to swap between summer/winter sets of wheels without having to reset the TPMS module twice a year, often costing $20-50 each time to reset at the dealer.
Two manufacturers have been marketing TPMS sensors that are programmable, so you can duplicate the sensor IDs from one set of wheels to another set of wheels. This, in theory, would make it much easier to have a winter set with cloned IDs that can be swapped in without having to reset the TPMS module, or to replace a single bad TPMS sensor in a wheel.
Schrader makes the EZ-Sensor, part # 33000, which is marketed as a single sensor that can replace multiple OEM parts, and Orange Electronics, which makes OPSS Sensors that are programmable. I had made several inquiries to Schrader trying to find a local retailer that sold the EZ-Sensor, but did not have any luck getting them to respond with usable information other than their marketing materials or directing me to locations hundreds of miles away. Their EZ-Sensor is pretty new in the marketplace, so it may simply be a matter of lack of distribution. Orange Electronics, on the other hand, was very helpful.
Orange makes replacement TPMS sensors with both fixed IDs and programmable ID OPSS sensors (more on OPSS later). They also sell a programming tool at a reasonable price that is very simple to use and works with most cars currently on the market. There are two different Orange sensors for Subarus, SCG00A or SCG01A.
Orange SCG00A - Replaces OEM Part # 28103AG00A - SCG00A - http://www.orangetpmsusastore.com/product.cgi?group=66&product=219
For use with:
2004 YEAR: Legacy, Outback
2005 YEAR: Legacy, Outback
2006 YEAR: B9 Tribeca, Legacy, Outback
2007 YEAR: B9 Tribeca, Legacy, Outback
Orange SCG01A - Replaces OEM Part # 28103AG01C - SCG01A - http://www.orangetpmsusastore.com/TPMS_Sensors-SCG01A.html
For use with:
2008 YEAR: Forester, Impreza, Legacy, Outback, Tribeca
2009 YEAR: Forester, Impreza, Legacy, Outback, Tribeca
2010 YEAR: Forester, Impreza, Legacy, Outback, Tribeca
2011 YEAR: Legacy, Outback (what is posted on their site, I would presume all 2008+ cars take SCG01A)
Programming tool T30
http://www.orangetpmsusa.com/oe-products/t30-tool/
http://www.orangetpmsusastore.com/product.cgi?product=80&group=75
http://orangetpmsusa.com/2OPSS_2_Manual_V2-2011.pdf
Full TPMS sensor catalog listing all available sensors
http://www.orangetpmsusa.com/TPMS2011.pdf
Orange Electronic
3116 West Montgomery Rd
Suite C-239
Maineville, OH 45039
United States
Ph: 888-407-8767
The T30 scan/trigger tool will scan the TPMS ID from your existing vehicle and then allow you to clone that ID to a new OPSS sensor. The tool will also allow you to manually enter an ID via the keypad in order to clone to a new sensor if you had a sensor that completely died and was not active to be scanned. They are running a special on the T30 tool right now for $150, which if you intend to do winter wheel swaps, pays for itself pretty quickly compared with doing the cost of doing TPMS module resets twice a year. If you purchased a newer Subaru down the road and kept your winter wheels, it is simple to reprogram those wheels to the new car.
I called up Orange and spoke with Connor Duffy in sales/tech support who was very helpful answering a couple of my questions. A few days later I had a T30 tool and a set of four SCG01A sensors for my Forester at a healthy discount price since I was buying them all together. The tool is extremely easy to use, if you can look up wiper blades or air filters at the auto parts store, you can use it.
First, I scanned the IDs on all four of my wheels and recorded each ID so I had them as a record. To scan, you run through the menu on the T30, pick your make/model of vehicle and hit the scan button while holding the antenna near the valve stem on the tire. A few seconds later the T30 will vibrate and show you the ID it has stored, along with the current pressure and battery reading.
To clone these ID's to the new OPSS sensors, do the scan process again, then you press the Cancel key (the large capital C key, not the slightly smaller capital C key on the alphanumeric keypad, genius industrial design, doh!) which takes you up a menu level and choose Copy ID. Take one of the new sensors and hold it up to the antenna on the T30 while pressing the transmit key and a few seconds later the cloned ID will appear on the sensor. It is important to do this cloning 10 feet away from other sensors to avoid inadvertently overwriting them with another ID. Repeat this process for all four sensors, rescan all the new sensors to double check they all have the new cloned IDs and you are done, ready to have the sensors installed. Very simple, and I was able to do the scanning/programming on all four wheels and new sensors in about five minutes.
Now, a few cavets. One of the new OPSS SCG01A sensors gave me a low battery warning after I cloned it, right out of the box. These sensors are sealed with no replaceable battery, so I called up Orange, spoke with Lisa Adams in customer service and had a replacement sensor in two days.
I then tried to clone the SCG00A's for my wife's Outback. I had found four of these listed new on Amazon for a ridiculously low price of $11.50 each and ordered them before I had the T30 tool. Once they showed up I attempted the same cloning procedure without success. The T30 would read both the new and old sensors fine, but I could not get them to clone. I called up Connor Duffy at Orange again to find out what was wrong.
What happened, and this is not made very clear on Orange's website, nor on Amazon, is that even though Orange markets their sensors as programmable not all Orange sensors are actually programmable. Even though they share identical part numbers, the OPSS code is the key, sensors that are not marked OPSS are hard wired and can NOT be cloned. So the SCG00A's from Amazon were packed back up and I ordered some OPSS versions from Orange and had them in a few days. I got them installed on my wife's winter wheels last night, and they appear to work great, no light on the dash!
Update: I had the SCG01A's installed on my car this morning. They work perfect, no TPMS light on either car now.
Great post, thanks! For some reason their application search only shows the '04-07 outback, not the '11 that I need it for. Good to know they have a better selection. The unreplacable battery bothers me though. The only question I still need to answer is should I get them. OEM ones are $55 and Heuberger will reset the system for free. So really, these would be more expensive for me but a lot simpler. I'll be at SEMA next week, I'll talk to them and maybe pick up a set.
#5 ·
All TPMS sensors that I've seen have sealed, non-replaceable batteries. Buying sensors as a set of four from Orange was about half the price of what OEM sensors would be at the price you listed, and for me, doing two cars made the payoff of buying the T30 tool vs. twice yearly resets pretty short.
The Orange website leaves a bit to be desired for doing parts lookups. The PDF I linked to is more current and show models through 2011. Here is the link again - http://www.orangetpmsusa.com/TPMS2011.pdf
If all this is true, how do you suppose it is that I was able to mount the OEM wheels (with sensors) from my 2008 Legacy GTB onto my wife's 2007 Outback XT, take the XT to the dealer to get the sensors reprogrammed, and have them work ever since? HPH
Bravo! Well done. Thanks for taking the time to research and write this article.
How much were your sensors discounted when you ordered them with the scan tool?
Does the tool have the ability to tell you the condition of the battery, other than the "below 10%" warning?
Does Orange give you an expected life?
If you knew the life expectancy, you could toss then out when they are nearly gone, rather than installing new tires and then finding them dead six months later. If not, I guess you might be better off buying new sensors after, say, four years? Five?
I like the price of the tool, I just think it looks too much like "My First Calculator" or something out of "Who Framed Roger Rabbit?"...
Why is it so huge and clunky? I bet it is 90% air space inside the case. (Oh yeah, I get it - so the tire store drones wont steal them.)
The ONLY downside for this approach that I can see is that if you take your sensors to a tire store for tire installation, and they bust a sensor on the machine, which is not at all uncommon, you might have to work them hard to get them to replace it for free, and there would be considerable down time while the new part is in transit (since you can bet they wouldn't have one on the shelf). If they break a sensor that they are selling you, obviously they would replace it free with only five minutes lost.
Can we make this a sticky?
John Davies
Spokane WA
Each set of four sensors was $120 when buying as a set.
Every sensor I read other than the one bad one out of the box read BAT:>50%, and the bad one read LOW BAT:<10%. I don't know if there is a BAT:<50% reading also, the T30 manual doesn't show that.
I suspect given they are powered by lithium batteries that the the battery readings over time would be above 50% until close to the end of life of the sensor. The output of lithium batteries in general is very constant until they are almost exhausted and then they drop rapidly, unlike alkaline and other types that have a more linear output with gradual degradation over time.
Most of the TPMS sensors, regardless of manufacturer, quote a 5-7 year life. The sensors go into an idle/sleep mode when they are not moving and would only be transmitting when the wheels are moving. Given the 5-7 year quote and average yearly mileage of drivers, it's probably safe to assume a 75,000-100,000 mile lifespan. But my wife's Outback has almost 80,000 miles and is close to five years old and all her OEM sensors read as over 50% battery left.
It does bear a striking resemblance to a Ti Speak & Spell, and is only slightly smaller.
#11 ·
Well, I pulled the trigger on these too. I got a set for the girlfriend's Outback and the programming tool to get everything set up. if you're considering one, remember, today's the last day before it goes up to $200.
To help make this a worthwhile purchase, I'm willing to program the sensors for those in Colorado so you don't have to buy the tool. I'm in the Springs but we could work something out if you're in Denver or nearby.
Both sets that I have in my and my wife's Subarus have worked flawlessly since they were installed in October 2011. Like I said in my original post, the only problem I had was with a bad battery on one sensor out of the box. The replacement and all the others have worked perfectly.
The Orange OPSS programable sensors are a relatively new product, but other than the programable functionality are built identically to their non-programable sensors they have had on the market for years.
I'm very happy with the purchase.
LOL that would be a chance to visit my sister in DC... lol but for 7 hours driving each way I'd be better off owning my own tool...
Actually.... This is a long shot, but my sister is driving here from DC for the weekend of 4/7 (easter) if you wanted to loan it out for a couple days... :) Shoot me a PM if you think we might work something out but I completely understand if you have no intention of handing your new tool over to someone you have never met...
Jonathan
#18 ·
This is a really great thread. It is funny how the respective model owners stick to their forums, so only Outback people know about this ;-) I have a WRX and if I wasn't considering an Outback I'd never have known about this.
On the converse, you CAN program the TPMS in your own garage, there is some other hardware for that, the ATEQ Quickset TPMS. The catch is you need to capture your sensor IDs ahead of time, the unit can read and write them but not get the sensor ID. Just another way to do the same thing. I also picked up another tool (ATEQ VT30) to read the sensor IDs so I can read any TPMS that my reader can talk to and program any car that the Quickset can work with.
I really like the cloning, right now I have to program the sensor IDs each tire swap (takes just a minute) but with the cloning method you don't have to do anything at all.
#23 ·
What am I missing here?
I tried ordering them online, but couldn't find anywhere that said "OPSS versions" so I figured I'd call the number.. No answer so I left a message.. 2 days ago still haven't heard anything?!
I'll try again today but you would think they'd call back ASAP for a sale?
Jonathan
#24 ·
OK I went ahead and ordered them, everything arrived quickly. Had the sensors installed and the summer tires mounted on the second set of OEM rims I bought,
Put the wheels on the car, and grabbed the T30 tool, and it does not read a sensor on my stock rims that came with the car?!? I tried all 4, I read the directions... The only thing I haven't done is uploaded anything from the web... Do I have to hook the tool up to my computer and check for updates before anything will work???
It detected the new sensors just fine... Even though they are the ones I want to clone TO. I want to clone FROM the original ones in my snow tires..
argh. Any ideas?
Jonathan
You are not going to like to hear this...but it is much easier to program the sensors BEFORE you have them mounted. That said, if you can read the sensors off your existing wheels, you should be able to program the new ones, even if they are on rims, it just may take several tries.
I found it much easier to read the OEM sensors when the wheel was off of the vehicle. You can read them when the wheels are mounted, but I found it is much easier to grab the ID's when they are off. Point the bulb end of the T30 tool as close to where the TPMS sensor rides on the rim, which is just inside of the valve stem, so stuff the T30 as far inside the rim as you can. Make sure you are using a fresh battery in the T30.
It can take several tries for it to trigger the sensor and transmit the ID and pressure data. Once you have the ID for each wheel, WRITE IT DOWN! While the T30 is smart enough to remember the ID and then write to a new sensor, you also can manually enter the ID to do a programming session.
#26 ·
That is what is weird.
The NEW orange electronics sensors it read no problem with them on the car.
The OEM Subaru sensors that have been on the car since new would NOT read...
The Orange sensors would read for a ways away...
OK here is the really weird thing: The TPMS light did NOT light up in her car with the summer wheels and tires with the new Orange electronics sensors?!?
WTF is going on? I am half tempted to take off a snow tire and see if the shop didn't steal my sensors and turn off the light or something...
Shouldn't the TPMS light come on the first time out of the driveway with un programed sensors????
Jonathan
#29 ·
OK update:
TPMS light came on and flashed after a 30+ minute drive.. Did not come on for 20 minute drives though...
Also got it to read and clone the new sensors.. You have to point the T30 at the TIRE sidewall right next to the valve stem.. even suggests that in the directions ;)
Also cloning is called "copy data" in the machine.. I only managed to store the info from one sensor at a time though.. But I wrote all 4 down ;)
Thanks for all the help! Now I just have to take it for a drive to make sure all is well...
This thread should be a sticky!!
Jonathan
Most charge about $50.
And you can get a second module (actually, the first guy to post about it was on LegacyGT.com) but yo ustill have to buy 4 sensors, a spare module, and have it programmed. Then you have to remove the seat (and the unserseat subwoofer, if you have it) 2x per year to do the swap.
Not impossible by any means, but a pain.
#32 ·
Anyone ever just disable the system?
Anyone ever just disable the system? I'm guessing there has to be a module somewhere that recives the signals from the tire transmitters. If one were to find it and remove its power supply, would we then have the idiot light on the dash still?
Have been driving for over 35 years, this TPMS is B.S. I wouldnt mind if the system were reliable, and could give you actual data on which tire was low and what the pressure readings are, but I have an intermittant light, all tires are fine. No way of knowing which tire has the bad sensor. I'm not about to continue to spend money on sensors and the like when its a poorly designed system and a user interface that doesnt provide any real data.
I suppose I could pull the dash cluster and I.D. wihich wire feeds that light, but I would rather not have to bother.
Jeff
