Do both rotors and brake pads need to be replaced - Subaru Outback - Subaru Outback Forums
 1Likes
LinkBack Thread Tools Rating: Thread Rating: 1 votes, 4.00 average.
post #1 of 43 (permalink) Old 01-11-2012, 11:38 AM Thread Starter
Car: 2008 Outback Limited PZEV
Dealer indicates pads on my 2008 Outback are below the '25% left' standard they use. Says they don't turn rotors anymore, cheaper to replace both rotor and pads. Seems over the top to me. Anyone have comments or recommendations?
Scotsman is offline
post #2 of 43 (permalink) Old 01-11-2012, 11:51 AM
I agree on not turning rotors (generally) but, I don't think we have enough info as to whether they need replacing. rotors will last for several pad changes unless there's a 'problem'.
1 Lucky Texan is online now
post #3 of 43 (permalink) Old 01-11-2012, 12:19 PM
Replace the pads and regrease the slides (properly checking and regreasing the slides will be far more important than the rotors).
If the brakes are not vibrating - you do not need rotors. Rotors last a very long time - 100,000 miles easily. they generally won't fail on a car this new unless something out of the ordinary happens or the pads are warn down to the rivets (which should never happen)
Rotors will look "warn" so it's easy to convince a customer that doesn't know any better to replace them - but in reality a brand new rotor looks like a used rotor in a month anyway, that's what rotors do. easy way to convince unfamiliar folks to replace rotors - "oh yeah i see the rust and markings on the surface"....well your new rotors they just milked you for will look just like that in a month - better stock up on rotors!
The brake pads have wear indicators on them and will make noise when they need changed - you probably have another year or so on on them.
anyway - let's hope they are and just say that replacing pads early is a fine practice. 25% is actually quite a lot of pad - if pads last 4 years that's 1 year of life still left.
brake jobs are REALLY freaking easy - once the wheel is off it only requires removing 2 bolts to replace brake pads. unbelievably easy.
grossgary is offline
post #4 of 43 (permalink) Old 01-11-2012, 01:26 PM
Bassman's Avatar
First, check your rotors for any cracks (heat checking), grooving, or as previously mentioned, any sign of warpage (sometimes there will be areas which are slightly discolored where the rotor has gotten hot, but there is no contact with the pad). You will also, as mentioned, feel vibrations on brake application with warped rotors.
Second, inspect the pads. You can wait until you hear the wear indicators, but I'd suggest you don't. If you're on a long trip, need to have the brakes done, and can't do the work yourself, you are at the mercy of an unknown shop for the repairs. Also, you don't have a lot of miles between the first audible noise from the wear indicators before the pad backing plate(s) can start wearing against a rotor.
If everything looks good, replace the pads, but don't turn the rotors. Again, as previously mentioned, rotors with normal, even wear patterns can last 100K miles or more.
Use silicon grease on the caliper guide pins and check the rubber boots to ensure they are not cracked or torn. Also, be certain that the pistons are free to move in and out without any binding. Then, be sure when you install new pads, that you clean off the surfaces of the rotors with Brakeclean or alcohol. The same with the surfaces of the brake pads. Then, be certain to "seat" the pads against the rotors with several, low speed (under 30) HARD brake applications.
Bassman is offline
post #5 of 43 (permalink) Old 01-11-2012, 01:46 PM
+1 to err on the side of caution - brake pads are rather cheap compared to rotors.
in my experience it seems that Subaru's (though that's all i work on) generally have a long time interval between wear indicators making noise and causing damage to the rotors. but that could vary by type of pad, driving style/conditions, condition of pads/rotors (if the slides are out of grease and in contact with rotors they will wear faster), etc.
lots of variables so best to err on the side of caution if you don't have a compelling reason to wait.
i am often changing wheels (winter to summer tires) so not a big deal to me as i'll be able to check again shortly and no extra work.
post #6 of 43 (permalink) Old 01-12-2012, 05:24 AM
Timberwolf99's Avatar
Car: 2000 Outback Limited, Dual Range 5 Speed
no one mentioned minimum thickness, get some verniers and measure the thickness if close to original tgickness then you could take them off and get them machined before putting on the new pads. if close to minimum thickness you could probably judge if machining will take them to under size and replace.
Don't follow me i may be looking for a cache!
Timberwolf99 is offline
post #7 of 43 (permalink) Old 01-12-2012, 11:16 AM
I :heart: SUBARU
porcupine73's Avatar
Car: '00OBW, '96&'94 Legacy
I think Subaru switched dealers to using an on-car brake lathe only, to make sure the rotors were machined parallel to the hub basically. But those things aren't cheap and still you're eating away rotor material, so it's probably just about a wash to replace them vs. machine them.
If the brakes aren't pulsating you could probably get away with just a pad swap. Ideally brake pads should be the same as what was on there in this case, to avoid any incompatibility between material that may be embedded on the rotors, though most lightly driven passenger cars end up with abrasive friction only. Ideally would be nice to clean up the guide/lock pins too just with our kind of nasty winters.
porcupine73 is offline
post #8 of 43 (permalink) Old 03-11-2012, 11:36 AM
Car: 1996 Outback MTX & 2001 Outback VDC H-6 ATX
A quick note: I have also experienced that rotors can warp/distort due to uneven or excessive torque on the wheel lug nuts. The major culprit is often impact wrenches at the garage, or people not tightening the lugs gradually and in sequence (like a star pattern).
bblooz is offline
post #9 of 43 (permalink) Old 03-11-2012, 11:54 AM
jp1203's Avatar
Got any mechanically-savvy friends that would spend an hour or two changing your pads and/or rotors? You have disc brakes all around, and working on them is very, very easy. You could probably do both pads and rotors on all four corners in a couple of hours even if it's your first time.
I agree with not turning rotors...they're not all that expensive, so it makes sense to just replace them IMO.
Current Vehicle:
jp1203 is offline
post #10 of 43 (permalink) Old 03-11-2012, 02:30 PM
Car: 2007 Outback XT Ltd
I've done lots of brake jobs over the last 35 years, and the only ones that made me unhappy were the ones where i didn't replace the rotors.
If you are really strapped for cash, leave them, as long as they have some life left. Otherwise buy new Napa Ultra Premium rotors and OEM pads, and be happy.
http://www.napabrakes.com/wps/portal...Ultra_Premium/
John Davies
Spokane WA
http://www.spokanister.net
John E Davies is offline
