#21 (permalink) | |
#22 (permalink) | |
#23 (permalink) | |
#24 (permalink) |
Car: 12 Outback 2.5i Limited/09 G37X
that is very odd, I've never heard of such problem, I could see somehow abs unit may faulty modulate and cause pedal vibration and noise, but I don't believe abs unit is able to apply and HOLD pressure at all 4 wheels. if I'm not mistaken it has failsafe system where should abs unit failure occurs it allows fluid to bypass for non-abs function. I would def get second opinion and perhaps resort to subaru specific service centers.
#25 (permalink) |
wow, crazy. buy used parts. this stuff fails so rarely that new would be silly, i mean you're not going to even find another subaru owner with these symptoms or ever see it again so new is over priced.
car-parts.com is a junkyard database. if you can't find exactly what you're looking for (like an obscure part not listed or something) - look up something close - like ABS module...and if they have that, then they may have the controller, wiring etc. disconnect the ABS electrical connectors or pull the ABS fuse or pull the ABS controller plug - or all of the above! 1. if the problem goes away then it's electrical in nature and the controller or relay likely needs replaced. 2. if the problem doesn't go away then the abs unit itself is probably mecahnically hosed inside. two things i'm not sure about is if the master cylinder or proportioning valve could fail in such a way as to apply constant hydraulic pressure to the brakes? i would suspect either the ABS module is mechanically hosed - replace it. it's fairly easy actually and not that big of a deal. unscrew fittings, install new unit, reinstall fittings. not that bad and while the "bleeding procedure" looks convoluted i've never really had to do anything but normal bleeding like any other brake component replacement, so not much to worry about. did you try a google search - seems like all 4 locked wheels would be a symptom one other person has had before.
#26 (permalink) | |
I :heart: SUBARU
Car: '00OBW, '96&'94 Legacy
I hope you get it figured out! I don't mean the person doing the service putting the wrong fluid in the brake reservoir, I mean since you bought this vehicle used, you a previous owner may have done it.
#27 (permalink) |
All four seized? I am guessing a master cylinder issue, a mis adjusted brake rod on the pedal. Some people like to adjust them which really sint suggested.
The ABS is passive untill it has to do something, so things just flow through it. Not working on hydraulics? Thats a copout as brakes are not that complicated. Another possability can be collapsed brake lines. |
#28 (permalink) | |
Car: 2003 LLBean H6 Outback
Brakes heat a tint bit, fluid expands, brakes drag. |
#29 (permalink) | |
Car: 02 Outback 2.5 5sp
James |
#30 (permalink) |
Car: 06 OBW 2.5i NA
Another thing to check is the lower slide pins on the calipers. Some of them have a rubber sleeve on the pin that loosens up and binds the pin in the bore. The sleeve is there to keep the pins from making a klunk as the brakes are applied. They can be replaced (the come in the pin boot kit). In a pinch they can be removed without affecting the opperation of the brakes.
My other car is a Subaru.... Come to think of it, so is my other other car |
