99 Outback/Baja Spring Swap - Subaru Outback - Subaru Outback Forums
Old 02-03-2012, 01:28 PM   #1 (permalink)
Car: 99 Subaru Legacy Outback Wagon
Default 99 Outback/Baja Spring Swap
I have a 99 Outback and wanting to lift it i want to go with one of two things one is to buy 05 baja springs and just swap out the springs and thats that but i heard that only gives about 1.5" lift or i was thinking about getting spacers and put them on but i dont know much about how the spacers work and what all i have to do for the spacers. ill take any info i can get
99subarulegacyoutbac is offline   Reply With Quote
Old 02-03-2012, 01:53 PM   #2 (permalink)
Car: 2003 2.5 4EAT with AWP.
Have you seen this thread also?
Using Forester Springs/Struts/Shocks to lift 1st Gen Outbacks
Old 02-03-2012, 02:08 PM   #3 (permalink)
thanks now theres three ways lol i want the most easest way and cheapest way to do it but in the very first post you can really tell a difference in the back sagging alot so idk which way i want to go now thanks for the link
Old 02-03-2012, 08:13 PM   #4 (permalink)
Car: 2001 Outback Limted 5MT
Sorry, but pretty sure Baja springs won't work with first gen outbacks. I would stick with forester suspension, you might get a little higher lift too.
mnfire is offline   Reply With Quote
Old 02-04-2012, 01:42 AM   #5 (permalink)
no 05 baja spring will fit the 99 outback i seen a few links on here where they have already done it with 05 springs i just want to see which is easier and cheaper from just swapping springs out or getting spacers specially made
Old 02-06-2012, 01:51 AM   #6 (permalink)
Car: 09 OBW base => 07 OBXT LTD 5sp
I assume you read thru this:
Baja Springs for a 2000 Outback Wagon
Impatient is offline   Reply With Quote
Old 02-06-2012, 09:33 AM   #7 (permalink)
thanks for the link really helped out
