Rear rotor caliper bracket bolts!??!? - Page 2 - Subaru Outback - Subaru Outback Forums
Old 12-08-2012, 10:56 PM   #11 (permalink)
cardoc's Avatar
Originally Posted by John E Davies View Post
LOL.....
John Davies
Spokane WA USA
You know, I look at that now and I can see why you laugh.
But if you look at it like I meant it, it makes sense. Using extensions between the ratchet and socket reduces the energy available at the bolt because the extensions will absorb it in the twisting of the metal.
Old 12-09-2012, 11:44 PM   #12 (permalink)
subyroo651's Avatar
Car: 2013 Outback 2.5Ltd w/EyeSight
pictures of what you're trying to do? I can recommend the right tool..
It can't be that bad.
subyroo651 is offline   Reply With Quote
Old 12-17-2012, 02:00 AM   #13 (permalink)
For anyone interested,
I bought a 3" extension for my 1/2" drive, didn't work
Harbor freight had a offset mtric set for 15 bucks, a quick check and it seems like it will work!
Now I know I'm about to find some serious hub rotor rust, and my rotors do not have the 8mm holes. How do I get the rotor off? I read hit between the lugs with a hammer? Any ideas
coult45 is offline   Reply With Quote
Old 12-18-2012, 07:41 AM   #14 (permalink)
cardoc's Avatar
Either use a hammer combo, ballpein and deadblow resting the ballpein on the rotor and hitting it instead of the rotor, or use the screws. You may want to soak the rotor and hub area with PB Blaster to eat up some of the rust to help. Try not to hit the wheel studs or you'll have to replace the one that gets smacked.
Old 12-18-2012, 08:10 AM   #15 (permalink)
rasterman's Avatar
Car: 2006 Outback XT Limited
Put the lug nuts back on to protect the stud threads from hammer whoopsies. They will also keep the rotor from springing off and falling on your toe once you bust the rust lock.
DBA slotted Legacy GT front rotors w/Carbotech 1541 front pads; Hawk HPS rear pads and SS hoses all around
No, I didn't rebuild my car overnight. Just testing a pimped out sig for a week or so...
Old 12-18-2012, 11:27 AM   #16 (permalink)
Well I didt even get that far on both sides. Broke off a caliper bolt, and I don't have the tools to rethread and drill it out. Off to the shop, this is no fun. My next car I will make sure to be rust free
Old 12-18-2012, 11:41 AM   #17 (permalink)
rasterman's Avatar
Yuck. Was that with an offset socket?
Old 12-18-2012, 07:04 PM   #18 (permalink)
No just a regualr 14mm, took it to the shop, 56 bucks in labor to fix the screw. Rust sucks
Old 12-20-2012, 12:51 AM   #19 (permalink)
subyroo651's Avatar
Yikes, I've been there before. Sadly that may have been prevented by using an impact instead.
