Tire Chains - Subaru Outback - Subaru Outback Forums
Old 11-28-2006, 10:23 AM   #1 (permalink)
Car: 02 OBW AT Aka The Wallaby
Default Tire Chains
I heard where chains are required on both sides of the Eisenhower Tunnel west of Denver.
I know nothing about chains as I live in Kentucky.
If I head out there with my 2002 OB Wagon.
What kind of chains do I need.
Are there different sizes?
Is there only one pair of chains per set?
If this is the case do I need two sets for the wagon since it is AWD?
If I only need one set would I put them on the front tires or the back?
Thanks,
RogueIT
rogueIT is offline   Reply With Quote
Old 11-28-2006, 11:02 AM   #2 (permalink)
Just call me T. B. Player
theletteri's Avatar
Car: '06 OBS SE
Send a message via AIM to theletteri
since you have all wheel drive you most likley do not have to put on chans. but if you would like to be safe (i carry chains that i got free) you would be fine getting one set. if your car is an AT you should put the chains on the front since the AT is 90%F and 10%R most os the time. if it is MT i would say the back would be good because then you are less likley to spin out.
this is only my opinion so i am in no way an expert. i hope i helped
2006 Impreza Outback Sport SE, Team Dynamics 15" rims, Yakima basket, Piaa 520 driving lamps, full size spare, 2" suspension lift, 27" General Grabber AT2 tires, 9.1" ground clearance
~Jason
theletteri is offline   Reply With Quote
Old 11-28-2006, 11:13 AM   #3 (permalink)
Flying Cavalry
cash fan's Avatar
Car: 05' 2.5i outback
I have never had to put chains on by the highway patrol for the subie or the jeep. but do have good all season (snow tires)
in CA, there road ratings... r1, r2... etc.
i think r4 is ALL vehicles must have chains, but most of the time it's chains req'd on all but 4 wheel/all-wheel vehcles with snow tires.
I've never seen an all vehicle chain requirement since they shut the road down to everyone before that happens. would you realy want to drive in those conditions?
I know for 4-wheel drive you need one set (2 chains) for each drive axle so it may be the same for all-wheel. you dont NEED chains on all 4 tires, but you lose effectiveness.
The only time i ever had chains on my jeep was for winter travel on northern minnesota trails to the shack and they stayed on all winter. in fact, i believe chains are illiegal on public roads there.
Also, check that your car takes chains. Many VW's dont (according to the owners manual) but people still put them on.
It's up to you if you want to carry chains, but make sure you have good tires and a solid emergency kit for winter travel. And, if you get chains, know HOW to put them on and tighten them.
cheers-
support your local singlespeeder
________________________
05 outback wagon
old school jeep wrangler
cash fan is offline   Reply With Quote
Old 11-28-2006, 02:27 PM   #4 (permalink)
Recruit
Car: 2005 Outback XT
Default CO Chain Laws
When there are chain laws in effect, there are 2 types used for non-commercial vehicles.
The first and most common is Chains or Adequate Snow Tires, tires must be marked with M/S or all weather by the tire manufactuer and have at least 1/8" of tread depth. Fourwheel drive vehicles are required to have a minimum of 1/8" of tread depth and conventional tread or adequate snow tires.
The second type is Chains Only, use of conventional steel link chains are required, but fourwheel drive vehicles are okay without chains. Check out the Colorado State Patrol webpage if you have more questions, http://csp.state.co.us
Living in CO for 31 years, I can only remember a few cases of the Chains Only law being used. Usually the chainlaws are used to keep the commercial vehicles moving, and the nightmare traffic jams to a minimum. Check your tread depth and get ready to wave to everyone as you pass them.
bigeazzy93 is offline   Reply With Quote
Old 11-28-2006, 11:11 PM   #5 (permalink)
IDK....my BFF Jill.......
ivwarrior's Avatar
Car: 2002 WRX MBP
If you decide to go with chains, check to make sure you're getting the right type. I have an owner's manual for a 98 Legacy here, and it says to use only SAE class S type chains of the correct size for you tires. It also says to keep your speed below 19 MPH when driving with chains.
One
Big
Ass
Mistake
America
ivwarrior is offline   Reply With Quote
