burning coolant smell - Subaru Outback - Subaru Outback Forums
post #1 of 4 (permalink) Old 04-17-2005, 10:42 PM Thread Starter
Car: 2000 subaru outback
Question burning coolant smell
so with the head gasket problem- would this cause a constant smell of burning coolant ? I find that my car always smells of burning coolant and asked about the problems I have heard about with the coolant additive which I had added. Does this mean I should always go back to subaru just to ensure that it is being done correctly or is regular coolant ok after the additive has been added. I noticed that the dealership didnt really want to talk about this problem and felt like I was being brushed off. I am going to take my car back into them and get a reason for the constant burning smell and push for a final answer.
subiekiller is offline
post #2 of 4 (permalink) Old 04-18-2005, 02:33 AM
I'm Not Slash...yet.
FMGreen's Avatar
Re: burning coolant smell
Originally posted by subiekiller
...I am going to take my car back into them and get a reason for the constant burning smell and push for a final answer.
Sounds like a good idea. I'd do it ASAP.
If you can't keep it clean, keep it green!
FMGreen is offline
post #3 of 4 (permalink) Old 04-18-2005, 05:47 AM
Tokyo's between my toes
The_Lizard's Avatar
One of the two common (too common?) head gasket failures involves an external coolant leak at the bottom rear of the left-side head.
Try this: when you park it after a good run, shut it off and let it rest for a minute and open the hood. Look down at that bottom corner, and the pipe, and look for drips and steam.
If you spot something, then you can take it to the dealer and say explain THAT.
Does it ever leave drips of coolant on the ground?
The_Lizard is offline
post #4 of 4 (permalink) Old 05-15-2005, 01:16 PM
sense of nature's Avatar
Car: 99 outback Limited 2005 Outback Xt Limited
Hello
also if there is boil over /overheating that's a good indication, the coolant reser evoir gets filled.cylinder compression bypasses the gasket pushing all ( almost all) the coolant out of the radiator, obviously causing an overheat condition
For all of Your Scooby needs
sense of nature is offline
