97 Outback R&R Head Gasket - Subaru Outback - Subaru Outback Forums
post #1 of 10 (permalink) Old 12-18-2009, 03:33 PM Thread Starter
IDOXLR8's Avatar
Car: 1997 2.5 Outback
Hi, guys! New to the "boxer" thing and want to learn more. I have a 1997 Subaru AWD Outback 2.5 DOHC auto and needs the head gaskets replaced. I've been in the repair line of work over 30 years on U.S. cars and new to Japanise cars. I plan to do the repair and would like some input as per if this is a good idea. From what I've seen, it looks like pulling the engine would be the best route. Looks like the cams need to be removed to get to the head bolts. I would be interested if anyone offers a detailed instuctions of the R&R of the engine and the R&R of the head gaskets, your input would be appreciated, AL.
Going Fast With Class
IDOXLR8 is offline
post #2 of 10 (permalink) Old 12-18-2009, 04:41 PM
Just pretend you are doing a really small V-8 engine that is spread far apart.
It can be done in the car, but easier out of the car. You can reuse the head bolts. Use ONLY subaru head gaskets and SUbaru valve cover and spark plug bucket seals.
If the engine is out replace the rear seperator plate if it is plastic. Replace main crank seal and reseal the oil pump.
Timing belt, idlers, tensioner, and waterpump should be replaced if they are unknowns.
Heads should be machined and rebuilt (since it is a 1997)
nipper
nipper is offline
post #3 of 10 (permalink) Old 12-19-2009, 07:53 AM Thread Starter
IDOXLR8's Avatar
Subaru Head Gasket Replace
I have a Haines book on the Outback that isn't bad but would like to find more information in order. The Haines book has information in all different sections. I thought I saw somewhere someone offering a instuction sheet specifically to this repair, for the R&R of the engine and the R&R of the head gaskets. Keep in mind I've never did the "boxer" thing, AL.
IDOXLR8 is offline
post #4 of 10 (permalink) Old 12-19-2009, 10:41 AM
wurkenman's Avatar
Car: 1998 Legacy Outback, 2.5, auto, Green
Pretty straight forward job. Easier to pull engine than to try the job with it in the chassis. When putting the engine back in watch the "tube" that goes from the torque converter to the trans, it's kind of a tricky little item that gets no attention in the Haynes manual. The manual also says to use gasket sealer on the gaskets. This is for the old style gaskets, do not use any kind of sealer on the gasket or the block/ head surface. When I did mine a year ago the cost was around 800 for parts. OEM gaskets from Subaru and a timing belt kit with all idlers and tensioner from ebay. The kit was 200 shipped. The idlers alone from Subaru are about 60 bucks each. Do the water pump while you are there too, cheap insurance.
2007 Legacy 2.5i
2005 Legacy GT 328 AWHP at 19 PSI
1997 Harley Custom Electra Glide
1998 Outback
wurkenman is offline
post #5 of 10 (permalink) Old 12-19-2009, 10:53 AM Thread Starter
IDOXLR8's Avatar
wurkenman, thanks for your reply! I did see the tube you noted and looked as if it would be in the way, so would it be advisable to remove it? AL.
IDOXLR8 is offline
post #6 of 10 (permalink) Old 12-19-2009, 01:35 PM
wurkenman's Avatar
There is a spring keeper on the ID of the tube. It needs to be "locked" on the torque converter and slowly rotate engine to seat it into the trans before you try to bolt engine and bell housing together. I put mine on and inserted the tube and engine as one. The first time I tried I had the engine in the bay and was trying to get the tube on the converter and snap it into position. Well the plan did not work so I had to pull the engine again and fish out the tube. Just be careful while installing engine with tube installed. Not a lot of room in there.
2007 Legacy 2.5i
1998 Outback
post #7 of 10 (permalink) Old 12-19-2009, 02:27 PM Thread Starter
IDOXLR8's Avatar
What is this tube? Does Subaru recomend this be removed? Will this engine come out with it hooked up? What do the two ends connect to? AL.
IDOXLR8 is offline
post #8 of 10 (permalink) Old 12-19-2009, 02:49 PM Thread Starter
IDOXLR8's Avatar
Wurkenman, a bit confused on your last post. I read this then read the other links. Are you in reference to converter to the transmission front pump assembly. What are you saying, the engine crank shaft hangs up on the converter centering shaft?
IDOXLR8 is offline
post #9 of 10 (permalink) Old 12-19-2009, 05:53 PM
wurkenman's Avatar
No it does not hang up, but with the engine dropped in the engine compartment, the tube will slide back down into position and it is very difficult to get both hands in there to lock it in place. It will come out with the engine. at least it should. Mine came loose when removing engine and at first I tried to install the engine with this tube still in the car. Once you have it out it will become a lot more clear. I was just saying that this one step in the process is not covered or even mentioned in the Haynes manual.
2007 Legacy 2.5i
1998 Outback
post #10 of 10 (permalink) Old 12-19-2009, 06:44 PM Thread Starter
IDOXLR8's Avatar
Suburu Head Gasket Replace
PM sent, AL.
IDOXLR8 is offline
