DOHC Head removal - Subaru Outback - Subaru Outback Forums
post #1 of 32 (permalink) Old 12-27-2009, 07:34 PM Thread Starter
Car: 1999 Outback limited
DOHC Head removal
2.5 dohc I'm getting close to the heads and just read a thread about not being able to remove the head bolts with out removing cams. Is this true. Can't find anything in here.
I don't want to go further if I have to remove engine. I'll put it back together and take it to a shop.
Frustrated!
subeedo is offline
post #2 of 32 (permalink) Old 12-27-2009, 09:26 PM
Yes, on the 2.5DOHC, one must remove the cams in order to access the head bolts. It's pretty tight, but can be done without removing the engine.
Once the timing belt assembly and inner timing belt covers are removed, removing the camshafts is easy. Removing/installing the heads is where it gets tricky due to lack of space.
EDIT:
Once the timing belt assembly and inner timing belt covers AND THE VALVE COVERS are removed, removing the camshafts is easy.
RobLog is offline
post #3 of 32 (permalink) Old 12-27-2009, 10:30 PM Thread Starter
Thanks,
I'll keep going then. Fun car to work on.
Rick
subeedo is offline
post #4 of 32 (permalink) Old 12-28-2009, 05:48 AM
wurkenman's Avatar
Car: 1998 Legacy Outback, 2.5, auto, Green
Pulling the engine is really a very simple process if you decide to go that route. Much easier to work on when the engine is removed.
2007 Legacy 2.5i
2005 Legacy GT 328 AWHP at 19 PSI
1997 Harley Custom Electra Glide
1998 Outback
wurkenman is offline
post #5 of 32 (permalink) Old 12-28-2009, 04:13 PM
daredevil1166's Avatar
Car: '99 Outback Limited, 2" Lift, 28" AT's, Winch, Dual-Range 4wd.
Much much easier to work on.
Pulling the engine is quick and easy. Only takes a couple hours.
I took mine out when I did my heads. It made it a ton easier to work on.
daredevil1166 is offline
post #6 of 32 (permalink) Old 12-29-2009, 01:27 AM Thread Starter
I'm not in a hurry since I have my dad's giant 85 Lincoln to drive. I have a engine hoist at work I can use. Better look for the engine removal thread.
Rick
1999 LTD
subeedo is offline
post #7 of 32 (permalink) Old 12-31-2009, 06:55 PM Thread Starter
Ok, I have just about everything ready to pull the motor, but I have 2 questions.
What do you do with the air conditioning?
Do I need ST (special tools) for removing the timing belt (dohc)? Not much in here about that.
Rick
subeedo is offline
post #8 of 32 (permalink) Old 01-01-2010, 11:23 AM
wurkenman's Avatar
For the air, just unbolt the compressor and tie it out of the way on the drivers side. I used a piece of wire to tie mine up. No special tools needed for thte timing belt. Good luck.
2007 Legacy 2.5i
1998 Outback
post #9 of 32 (permalink) Old 01-02-2010, 02:57 PM Thread Starter
ARGH,
Whats the secrect to get torque converter bolts out? They have a small head on them and I can't break them loose. I don't want to ruin them. Looks like I might have to remove the intake first.
Rick
subeedo is offline
post #10 of 32 (permalink) Old 01-02-2010, 03:06 PM Thread Starter
I got it. Just needed a bigger wrench. It's nice to know I can whine alittle and move on.
Rick
subeedo is offline
