Warped Heads? - Page 2 - Subaru Outback - Subaru Outback Forums
Old 01-07-2012, 12:23 PM   #11 (permalink)
canubaru's Avatar
Originally Posted by duckamuk View Post
Last, this might be blasphemy, but I've read some posts of people using additives to seal gasket leaks - any opinions on these type of products?
yes for some subarus and additives. the official ''coolant conditioner'' from the dealer for 00 - 04+ SOHC engines that tend to have the external gasket coolant leak.
no for every other product and every other engine, Especially the 96 - 98 ej25 DOHC engine. nothing helps those except replacing with subaru gaskets.
i hope you got your fixed.
Old 01-07-2012, 02:26 PM   #12 (permalink)
My opinion is that there is currently nothing wrong with your car. After a 500 mile trip with not a blip on the temp gauge and no loss of coolant pretty much tells the story. You would know by now if combustion gases were getting in the coolant from a bad headgasket. The original diagnoses was incorrect and I would not go looking for trouble.
2001 Subaru Outback 2.5 SOHC, AT, 107,000 miles
John
jbwood5 is offline   Reply With Quote
Old 01-07-2012, 03:02 PM   #13 (permalink)
Correct no car with a blown HG will do 500 mile trip without some type of coolant loss and temp spikes which are quite obvious. Don't mess with it
subiesailor is online now   Reply With Quote
Old 01-09-2012, 09:27 PM   #14 (permalink)
duckamuk's Avatar
Car: 2007 Outback Basic
The latest is that now when I drive it with the heat on I get warm air coming out from the driver side vents, and cold air coming out on the passenger side vents. The dash gauge doesn't show any change and I didn't notice any antifreeze smell. It's too dark out to see if I've lost any coolant, but this was a short trip into town. Does this indicate anything? Unfortunately my mechanic can't take the car until Wednesday to check it out. I'll check that in the morning.
duckamuk is offline   Reply With Quote
Old 01-10-2012, 08:34 PM   #15 (permalink)
frankspinz's Avatar
Car: Outback 2005 manual
Perhaps this thread can shed some light:
Passenger Heat Issue??
Sediments or air can interfere with collant flow:
I've never taken down the heater duct system so can't answer with a high degree of knowledge, but based on my understanding (service manual etc) of how the system is put together, I don't think debris would be a likely factor. And given the similarity to the previous poster, where there was a cabin filter in place, it would seem there might be another reason for the difference.
A small temperature difference is considered "normal".
This is from February 2008 Subaru "TechTips":
" . . . We have received calls with a Customer concern of cold air coming out of the passenger side vents as compared to the driver side temperature which is quite warm. Keep in mind that up to a 15 degree variance is considered normal. In some cases, the condition arises after cooling system servicing but it can also happen with the vehicle’s original coolant. When draining and refilling the system, sediments become agitated and get re-circulated. Eventually, they collect in the heater core and restrict the coolant flow causing uneven temperatures across the core which result in inconsistent vent temperatures. Air pockets generated in the cooling system during the coolant replacement can create similar conditions. Vacuum-assisted cooling system re-filling tools . . . are a handy tool to help eliminate air pockets and the problems they can cause."
Just bought a 2005 Subaru Outback 2.5 MT
with 160 000k ... My second ride is and off-road/expedition modified 2003 Nissan Xterra ...
My wife drives a 2006 Legacy Wagon . Previously owned a 2000 Outback and a 1996 Loyale ...
frankspinz is offline   Reply With Quote
Old 01-10-2012, 09:00 PM   #16 (permalink)
duckamuk's Avatar
Thanks, I saw that post this morning. Don't know if it's a good or bad thing - if the gasket is leaking air into the system causing this, or it's just a function of the recent coolant change. Hopefully I'll have better info tomorrow.
Old 01-11-2012, 08:00 PM   #17 (permalink)
duckamuk's Avatar
Brought the car to my other mechanic this morning, who determined there's nothing wrong with the head gasket!
He pressure tested the cooling system and found no head gasket leaks. Also performed a hydrocarbon test and found no signs of gases in the cooling system! As for the cold air coming out on the passenger side vents they said it was the right side blend door actuator needs to be replaced.
He also asked me which Subaru dealer I used because he's recently had two other Subaru's in for other problems that a local dealer mis-diagnosed. Wasn't my dealer, but it doesn't bode well for Subaru service in Northeast Pennsylvania.
Thanks to all for your input!
Old 01-13-2012, 11:18 AM   #18 (permalink)
frankspinz's Avatar
...Thanks to all for your input!
These Forums are great aren't they !? Glad this turned out to your advantage...
