#11 (permalink) |
Help... I have a Subaru Outback 2005.. thought I needed the timing belt replaced... and just had a check-up in November..
This is from a small shop... haven't checked with the dealer yet. Any thoughts or words of wisdom? -- Labor/Notes --- $1,229.06 CYLINDER HEAD GASKET - R&R M Includes: Remove carbon, check surfaces for warpage, adjust valves and ignition timing where applicable. $201.92 OIL PAN GASKET - R&R M --- Parts --- $298.37 Cylinder Head Gasket Set $279.64 Cylinder Head Bolt Set $13.26 Oil Pan Gasket Set $711.70 Timing Component Kit $126.00 Water Pump - New EngineAspiration:Naturally Aspirated; $14.14 Crankshaft Front Seal Set $23.82 Belt - Alt & P/S $24.99 PREMIUM BELT $20.93 All Vehicle Antifreeze $3.97 STANDARD OIL FILTER $13.00 5W30 SYNTHETIC BLEND OIL $31.08 SPARK PLUG $96.45 SPARK PLUG WIRE SET --- Charge/Misc --- $135.00 MACHINE SHOP SERVICE - REFINISH HEADS Note: M - Labor Database, Copyright, Mitchell International, All Rights Reserved ------------------------------ $1,430.98 Labor $1,657.35 Parts $0.00 Sublet $39.86 Misc. Shop supplies $0.00 Charges $99.44 Sales Tax (Tax @ $1,657.35 * 6.0000%) ------------------------------ $3,362.63 Repair Total |
#13 (permalink) |
Car: 1998 Legacy Outback
I'm late to this thread...
In Delaware for my '98 OBW, the best dealer quote was $1400 for head gaskets only, the worst was for $1800 labor-only. (No machining in either quote.) I went with an independent shop who machined the heads, new front and rear crank seals, new oil-baffle plate, new cam seals, new valve stem seals, valve adjustment, and all new gaskets of course. (I had just replaced the timing belt, idlers, and water pump.) Total of parts plus labor was $2400. |
#14 (permalink) |
Car: 1997 Legacy Outback, DOHC, Auto
The guys I bought my Subie from had one in the shop that they did heads one and the only way they would do was to pull the whole motor. But talking to them, they said that is the correct way to do these cars and I trust them. Not sure what they had in it, but it was heads being sent out and checked and re installed, new timing belt, water pump and oil pump.
#16 (permalink) |
Car: 2006 OBW 2nd owner -Legacy model
quoted $ !657 for timing belt and head gasket repair---praying that is all that is needed !!!!! Hoping I can put it off for a while --smells hot when idling --no overheating --has 142,200 miles now -OIL CHANGES EVERY 6-8 WEEKS
#17 (permalink) |
Car: 2002 Impreza Outback 4spd Automatic, 2.5 4cyl.
I'm about to embark on this trip myself. Last week my wife and I bought an 2002 Outback Sport. Car came with one FOB so we headed to the dealer and while the car was in they replaced the lower control arms. While they were under the car they noticed a lot of oil coming from the heads. I got quoted $1850 for the heads and timing belt. I'm hoping that's it. We're still several weeks away from having the money to even do it.
#18 (permalink) |
To keep this thread up to date, will post my costs, parts, and labor when she is out of the shop later this afternoon. Honestly, I am PO'd about the repair at 103K but my dealer seems to be reasonable since she is already in for the timing belt work plus "while we are in there" fixes.... More to come later.
AGE |
#19 (permalink) |
Car: 2000 Outback SW Limited
$2,235.66 List Price: $2,638.08 Save: $402.42 Core Deposit: $440.00
MARSHALL ENGINES PREMIUM PLUS LONG BLOCK, REMANUFACTURED |
#20 (permalink) |
Car: I own 3 Soob Legacies. A 95,97 and 02. The first two are 2.2 and the last a 2.5.
Yes, Oldage, you are right to be PO'ed. It's just too much money to pay at 100k! However, you are a little fortunate since you have 15K more miles then I have on my 02 which has leaking hg's.
Please post whether they took the engine out of the car, whether they machined the heads, and the type of HG you decided to install. The 633 is the standard Subaru replacement gasket, for example. |
