How much did you pay for head gasket replacement? - Subaru Outback - Subaru Outback Forums
Old 01-07-2012, 11:50 PM   #1 (permalink)
Car: 2005 Outback Limited
Default How much did you pay for head gasket replacement?
I've seen a few posts saying this shouldn't cost any more than $1200 to $1500, but that is going to differ based on what you get done.
So far I've been quoted $1900 by the dealer, which will apparently go up if the "heads are bad." I assumed they mean warped.
An independent subie shop quoted $2600 which includes pulling the engine, machining the heads, timing belt, tensions, idlers, water pump, a bunch of seals, fluids, etc.
Another independent subie shop wants $3200.
Am I getting screwed here? What have posters here paid?
Of course if you did the job yourself, feel free to gloat about how little you spent
TwoFortyJeff is offline   Reply With Quote
Old 01-08-2012, 12:20 AM   #2 (permalink)
Car: 2003 2.5 4EAT with AWP.
In my neck of the woods, adding a HG repair to the full timing belt service is about $1800-$2000 depending on if the heads need to be machined or just checked.
Old 01-08-2012, 12:22 AM   #3 (permalink)
If you went the one in Kent or the North End, that sounds about right. I also noticed that the pricing in the Seattle area does not match up to prices quoted on the board.
NWSub is offline   Reply With Quote
Old 01-08-2012, 12:35 AM   #4 (permalink)
bigdadi's Avatar
I saw in yelp.com that they're specialized in Subaru & very good review ... why not give them a call.
Lioe's Automotive
2400 Beacon Ave S
(between S 14th Ave & Bayview St)
Seattle, WA 98144
Neighborhood: Beacon Hill
(206) 323-2828
Hours:Mon-Fri 9 am - 5 pm
Sat 9 am - 1 pm
bigdadi is offline   Reply With Quote
Old 01-08-2012, 08:44 AM   #5 (permalink)
Here is what I'm getting in the north of North Carolina:
Dealer $1,700-1,800 with engine in, ~$2,100 with engine out. However, among three dealers, I could find only one who had a mechanic who was willing to pull the engine, and that only very reluctantly. Also, they are not willing to put in the head gaskets I want, so I declined.
Independent shop that I eventually chose: $1,450 with engine in, ~$1,750 with engine out. Add to that, timing belt plus all the trimmings (idlers, tensioner, water pump, etc.), a new oil pump (because mine is spewing oil), a separator plate, and some extras (change fuel filter - could have done that myself - and ATF), seals, etc., it'll come to about $3,200. Other shops were similar.
In the end, prices were within about $300-400, not too bad given the job. The difference was small enough to choose by how I feel about the shop and not by price.
Hope that helps.
PS: Before you get disappointed by the DIYers who will say "oh, only a few hundred bucks", take into account the cost of all the tools required, the labor, and the time it took to acquire the expertise to get the job done correctly
xvimbi is offline   Reply With Quote
Old 01-08-2012, 02:26 PM   #6 (permalink)
Car: I own 3 Soob Legacies. A 95,97 and 02. The first two are 2.2 and the last a 2.5.
My quote from a Wisconsin dealer is $1800 not including water pump, timing belt, idlers etc. They leave the engine in the car and do not sent the heads out for machining.
mikec is offline   Reply With Quote
Old 01-09-2012, 02:37 PM   #7 (permalink)
Car: 01 outback
My repair was 3500 for head gasket, timing belt and a bunch of other stuff (belts, tensionsrs, transmission flush, etc...)
Scott
2001 Outback 2.5
srpuywa is offline   Reply With Quote
Old 01-09-2012, 03:13 PM   #8 (permalink)
As a DIYer, I can understand some of these prices. I was just reading some of the other posts and I see where a guy had one of the headbolts snap off in the block when trying to loosen it. That kind of problem will potentially add a couple of hours and might even require engine removal. These shops have to inflate their prices to cover these contingencies. They may do 4 or 5 with no problem, but the 6th one might take them 15 hours instead of the usual 10-12 hours.
Sure, a DIYer can do this job for $400 to $500 plus 10-12 hours of labor but that is assuming everything goes as planned. There really are no special tools required, but for doing it with the engine in-place, you need a few combination of extension shafts and a good 3/8" torque wrench. It is a lot of labor and a lot of moving from below the car to under the hood (up and down many times during the project).
2001 Subaru Outback 2.5 SOHC, AT, 107,000 miles
John
jbwood5 is offline   Reply With Quote
Old 01-09-2012, 06:13 PM   #9 (permalink)
Car: 2012 2.5 Limited! 1999 Limitd
Had my 99 OB head gasket replaced after blowing it up in the mountains. Was done by an independant certified mech. $2400 all up with tax and towing
No for the bad news- I had just paid for the timing belt replacement 7 week earlier....ouch.
waterboy is offline   Reply With Quote
Old 01-12-2012, 04:25 PM   #10 (permalink)
Car: '98 Legacy Outback 5-speed
I just had mine done on my '98 OB at an independent Subaru specialist. Came to $1,720 out the door and included:
HG, cam seals, valve cover gaskets, front seal, etc.
TB, tensioner, water pump, tstat
Accessory belts
Oil change / filter
And a repair to the exhaust ($40)
No machining was required and I didn't think to aske whether the engine was removed or not. Either way, I'm happy with the work and I thought the price was fair.
Luke3026 is offline   Reply With Quote
