Mobil1 and Blow-by - Subaru Outback - Subaru Outback Forums
Old 09-09-2009, 09:37 PM   #1 (permalink)
Car: 2007 and 2001 Outbacks
Default Mobil1 and Blow-by
I've always used Mobil1 5W-30 full synthetic since I bought my '07 Outback with 5,600 miles on it, and always use Subaru oil filters. I change the oil every 6k because I drive a lot of highway miles.
So I call the local Subaru dealership to ask about the Mobil1 0W-30 and he tells me what I expect to hear: "If you want your warranty to stay valid, use the 5W-30". AND, he goes on to tell me that Subarus are have HORRIBLE blow-by issues when using Mobil1 and he highly recommends I use something else. Ever heard of this?
Also, I have noticed that when I drive at 75-80 mph for a while, I burn through some oil when using Mobil1. Ever experienced this?
I'm going to try Castrol Edge full synthetic for my next oil change at 50k and see what happens.
Also, I saw the poll and it looks like 50% of us use Mobil1.
All comments/thoughts are appreciated!
OutMax
OutMax is offline   Reply With Quote
Old 09-10-2009, 12:36 AM   #2 (permalink)
Car: 2009 Outback Wagon, 2.5L, Special Edition, 4EAT
I am still in the break in period on my 2009 Outback but when I hit 3500 miles I am changing to Amsoil 5W30 100% synthetic. I have used Amsoil in all my other vehicles and change the filter every 6 months and do a complete oil change every 12 months or 25,000 miles. Synthetics in general reduce wear and the result is cleaner oil over a longer period of time unless the engine is not sound to begin with. My 1996 Explorer had 161,500 miles on it when I traded it for my new Subie and I changed the oil every 12-14 months or 25,000 miles & the only other maintenance was plugs, wires, and timing belt. Check out www.amsoil.com for more information about viscosities, etc.
Why do you want to change to 0W30? It would perform better at lower temperatures when the engine is cold, but if most of your driving is highway, the operating temperature of the oil will be fairly warm anyway. As far as voiding your warrantee, the dealer would have to prove that the 0W30 oil was the direct cause of any failure.
Also, it has been my experience that if you are getting blowby, it is possible the rings are not seating properly, are worn, or something is out of tolerance. As long as the viscosity index is the same, one oil should display the same flow characteristics as another at normal operating temperature. The advantage of synthetics is that they are slicker than petroleum based oils and tend to create less wear in a sound engine allowing for the extended drain intervals. They also have a lower pour point and therefore lubricate better at lower temperatures than petroleum products. But I have also seen synthetics clean the sludge deposits created by petroleum products around seals resulting in leaks.
szeichdog is offline   Reply With Quote
Old 09-10-2009, 07:46 AM   #3 (permalink)
Button's Avatar
Car: My-'06 Outback 2.5 i Limited Wagon & Wife's '08 Outback 2.5 i Limited Wagon
Send a message via AIM to Button
OutMax,
I currently use Amsoil SSO 0W-30 & both '06 & '08 like to consume/burn between oil change intervals. Nevertheless, I will be trying Amsoil 10W-30 on my next change to see if it helps w/ the consumption.
Regards,
~Button
I yearn for Portsmouth & the White Mountains!-!-!
R.I.P. '04 Gas Swillin' Chevy Hoe
Button is offline   Reply With Quote
Old 09-10-2009, 09:14 AM   #4 (permalink)
neutron's Avatar
Car: '11 Outback 3.6R (5EAT)
Any API-labeled oil shouldn't change blow-by characteristics. Blow-by is affected by ring sealing, and as long as there's oil of any weight on the piston, the rings are essentially sealing to their design characteristics. (I don't see any TSBs regarding this matter either.)
neutron is offline   Reply With Quote
Old 09-10-2009, 09:57 AM   #5 (permalink)
Mig Insultor
Hooray's Avatar
Car: 1998 Subaru Legacy Wagon 5 spd
i have heard a lot of hate against mobile 1...blow by, seal degredation etc
i have used it along with other synthetic brands no problem (though i use dino oil in my subie)
many people prefer amsoil and other expensive brands (not that mobil 1 is not)..but i think that some of the preference comes from perceived protection due to the higher price
in the ensuing replies someone can insert all the charts and graphs to show that super expensive oils are better but i will still not be convinced
to each his own
I yearn for the time when motor sports were dangerous and sex was safe
Hooray is offline   Reply With Quote
Old 09-10-2009, 09:58 AM   #6 (permalink)
Car: 2007 Outback 2.5i - 5spd
2007 2.5 non-turbo with 54k. Have used Mobil1 5w30, first changed at 1k, then every 5k with Subaru Filter. Haven't had to ad a drop of oil yet.
2007 Outback 2.5i (Brilliant Sliver Metallic), 5spd, Sub-woofer, Extended ArmRest, Fumoto Valve
jnovember is offline   Reply With Quote
Old 09-12-2009, 01:06 PM   #7 (permalink)
Car: '05 Outback XT
I bought my '05 OBXT in Dec. '07 with 32,000 miles on the odometer. It now has about 53,000 miles on it. I've used Mobil 1 5W30 and a Subie filter every 3,000 miles since I bouight it and have never had a problem. I've never had to add any oil between changes.
Don
DonRich90 is offline   Reply With Quote
Old 09-12-2009, 04:13 PM   #8 (permalink)
Car: 2001 OB 2.5L Basic
Out of curiosity here...how many miles were on the other vehicles before you changed over to synthetics
Petersubaru is offline   Reply With Quote
Old 09-12-2009, 04:15 PM   #9 (permalink)
Don
5/30 dino or syn ??
Old 09-12-2009, 09:42 PM   #10 (permalink)
fuel98rider's Avatar
Car: 2008 Subaru Outback 2.5i Limited
Send a message via AIM to fuel98rider
I have used Mobil 1 5w-30 since the first oil change at 3,000 miles. After 27,000 miles, I do not get oil blow-by or oil consumption. I put 4 quarts in, and I get enough out to come within a 1/4" of the top of a gallon milk container. That beats any GM product I have ever owned.
I don't know whether Mobil 1 is truly better than anything else for my Subaru. I usually do not let price be a deciding factor on most decisions about my car. I do know that I spend zero time worrying about my oil with Mobil 1 in the car.
2008 Outback 2.5i Limited
2006 Honda Pilot ELX
2003 Trek Fuel 98 (Mtb bike)
2002 Trek 5500 (Road bike)
1996 GT Zaskar (Commute bike)
fuel98rider is offline   Reply With Quote
