Mixing brands of oil and weights - Subaru Outback - Subaru Outback Forums
Old 06-03-2011, 07:03 PM   #1 (permalink)
Car: 2008 outback, 2.5I
Default Mixing brands of oil and weights
Is it a big deal to mix brands of oil and weights?
I ask because I have quite a few partial quarts of oil that I would like to get rid of. It is all Full Synthetic, and a mix of 75% Mobil 1 and 25% Valvoline. It is all 5W-30 except for 1.5 quarts of 5W-0. I have 2 oil changes to do in the Subaru and the Honda I have enough quarts to do both oil changes, but if the 1.5 qts of 0 says it offers the same protection as 5-30, can I use that up?
Odd situation but I'm getting sick of all these partial quarts of oil. With every vehicle using somewhere between 4 and 5 quarts of oil, I'm always left with a little bit and it's just pissing me off this evening.
Thanks.
PS: If it matters, I have almost 90,000 miles on the car. 2.5 auto.
rykertest is offline   Reply With Quote
Old 06-03-2011, 07:48 PM   #2 (permalink)
Car: 2003 2.5 4EAT with AWP.
1.5 quarts of what? 5w0 does not exist. 5w20, 0w20? And yes, you can make a blend with little effect.
2003 Outback: "Kaylee". 128,000 and counting.
Old 06-06-2011, 06:30 PM   #3 (permalink)
Car: 2006 Outback/ non-turbo, auto
No problem mixing 0w-30 and 5w-30 from different manufacturers. One reason for having API Specs is that the products are compatible. Fleets that select lowest bidder lube contracts change oil brands regularly.
TS
TooSlick is offline   Reply With Quote
