Gas tank won't take gas....??? - Subaru Outback - Subaru Outback Forums
Old 07-07-2011, 03:04 PM   #1 (permalink)
Default Gas tank won't take gas....???
I have a 2004 Subie Outback with 80K on her. For the last year or so I have had an on-again/off-again issue with filling my gas tank. As I try to pump gas into the tank after 2-3 seconds the pump will shut off and gas will spray back at me from around the hose nozzle. Then whatever gas I pumped into the tank will surge back up and pour out of the tank opening. It's as if there is some valve that is not opening to allow ventilation for fill up. I took it to my Subie specialist who said he'd never heard of such a thing. He changed a fule sensor and cleaned out my fuel tank valve thinking that was it. It wasn't. It will not happen all the time and there seems not to be a trigger. Type of pump (vapor sleeve vs. non-vapor sleeve) makes no difference, whether the tank is empty, half full, 3/4 full does not matter. Sometimes the check engine light comes on, sometimes not. I ran out of fuel on the way home and was able to sneak 2.5 gals from a gas can and then took it to the station to fill and it worked whereas my 4 attempts to fill her over the previous 3 days failed. Engine light was on code P0457 Evaporative Emission Control System Leak Detected. Any ideas?
SolidRockRanch is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 03:12 PM   #2 (permalink)
This can happen when the vent valve gets stuck. Not a common issue but also not an uncommon issue either. The fix is to replace the vent valve the down side it it generally involves some labor time to get to it.
subiesailor is offline   Reply With Quote Quick reply to this message
Old 07-07-2011, 04:38 PM   #3 (permalink)
Thanks - I'll share the info with my mechanic.
Old 07-22-2011, 02:17 PM   #4 (permalink)
Any resolution for this one? I have same issue with '00 Forester. I've finally resolved to dropping the tank at some point because it seems like vent line to Evap canister is clogged (spider webs?) - but my daughter swears that sometimes it takes gas normally. Weird.
Thanks,
Wally
wallyblackburn is offline   Reply With Quote Quick reply to this message
