2013 Outback Amsoil Oil & Filter - Subaru Outback - Subaru Outback Forums
post #1 of 21 (permalink) Old 02-04-2013, 01:07 AM Thread Starter
kyoo's Avatar
hey all,
getting ready to test out amsoil's SSO 0W-20 for more or less a 12-15k miles/1 year OCI (will check oil regularly etc of course) but I was wondering - for those of you 2013 outbacks, do you guys know if Amsoil has an equivalent oil filter? Right now it's listed as no product recommended, so I'm not sure if I should just buy the oil and then get a filter from the Subie dealership or what.
Also, do you guys think running an extended OCI with Amsoil is potential for a warranty issue later down the line if there is a failure? Thanks
kyoo is offline
post #2 of 21 (permalink) Old 02-04-2013, 02:06 AM
gls
Car: 2013 Outback Limited 2.5i
Subaru's filter for the 2.5 2013 outback has a higher bypass design than most. The oil filter aftermarket really hasn't caught up yet, and high capacity oil filters aftermarket filters are not readily available. For your 5/60 warranty period I would stick to Subaru filters and 0w-20 synthetic oil with 7500mi oil changes. You can still use any oil that meets the specs. Mobil 1 AFE 0w20 is a lot cheaper than Amsoil, about $25/5qt at Walmart. Even Subaru oil at the dealer is cheaper. If you use Subaru bucks you can get all of your maintenance done free too
It's hardly worth the risk of voiding your warranty just to save a little on maintenance. The Subaru oil filters are not designed for extended drain intervals anyway. I'd wait until you are past the warranty period and hopefully high capacity filters will be available then.
gls is offline
post #3 of 21 (permalink) Old 02-04-2013, 09:49 AM Thread Starter
kyoo's Avatar
gotcha, thanks for the info
kyoo is offline
post #4 of 21 (permalink) Old 02-04-2013, 11:58 AM Thread Starter
kyoo's Avatar
just to confirm though, there IS a risk of voiding warranty going with a longer OCI? even like 10k miles?
kyoo is offline
post #5 of 21 (permalink) Old 02-04-2013, 01:25 PM
Yes. The maintenance schedule is actually a schedule, and 7500 means 7500......it does not mean 10,000-15,000, or when you get around to it.
4wheeldog is offline
post #6 of 21 (permalink) Old 02-04-2013, 01:34 PM Thread Starter
kyoo's Avatar
gotcha.. didn't know subaru dealerships were that stringent.
kyoo is offline
post #7 of 21 (permalink) Old 02-04-2013, 01:39 PM
fatabbot's Avatar
Car: '08 Veracruz Limited
Every auto manufacturer is the same way. They don't have a "unless you use Amsoil" clause in their maintenance schedule.
Enjoy your Outbacks
fatabbot is offline
post #8 of 21 (permalink) Old 02-04-2013, 01:43 PM Thread Starter
kyoo's Avatar
lol well i figured in case of something breaking down they'll try to find whatever they can to void the warranty, even if i had UOAs for every oil change.
kyoo is offline
post #9 of 21 (permalink) Old 02-06-2013, 02:57 PM
Car: 2011 Outback Limited/2.5L/CVT
I've been running extended service intervals with Amsoil for 35 years, including many new vehicles under warranty. Provided the engine is mechanically sound, there are simply no issues - the oil works exactly as advertised (several of my oil analyses are posted in this forum). In vehicles under warranty, I also take used oil samples at the end of a 15,000 mile change interval and have them tested. This is done mainly to make sure the engines functioning normally. This is the procedure I'd recommend for new vehicles under warranty. Once you've established a suitable service interval, there is no need to do oil analysis, unless you strongly suspect a mechanical issue.
As for the filter, Amsoil does not yet spec one for this application. I'd recommend using the OEM filter and changing it halfway through (6000-7500 miles or six months), your anticipated service interval for the oil.
If you have any further questions, please PM or email me....
TS
TooSlick is offline
post #10 of 21 (permalink) Old 02-06-2013, 04:32 PM
TS
All that is wonderful.......Until the motor pukes, and you expect a warrantied repair or replacement. Following the manufacturer's maintenance schedule leaves less room for them to weasel out.
I take it you have never had a motor go boom during the warranty period. If you do, I hope Amsoil steps up and covers the repairs......Because it is unlikely the manufacturer will......Even if it was not a lubrication failure. Good luck.
