Biggest tires for H4 02 OBW - Subaru Outback - Subaru Outback Forums
Old 07-30-2008, 06:57 PM   #1 (permalink)
Recruit
koala's Avatar
Car: 2002 Outback H4
Default Biggest tires for H4 02 OBW
I was just wondering what the biggest tires i can fit under my 4 cylinder 02 Outback wagon are i know i cant go much bigger than stock 225/60 but anything to gain any clearance would be nice.
I am considering getting a small suspension lift eventually but for now i just need some new tires my Potenza G009 are ready to come off.
My car will see very little snow but i do travel a lot so id like to be prepared for whatever.
Oh so i'm pretty sure this is my first post so, hello everybody.
koala is offline   Reply With Quote
Old 07-30-2008, 09:01 PM   #2 (permalink)
obsolete's Avatar
Car: was a 2002 OBW 2.5L AWP
Welcome to the forum! Looks like your car is identical to mine.
I am running 215/65/16. They are perfect, with no rubbing. These aren't much bigger, if at all, but they're a little higher profile, so they do take the bumps slightly better.
obsolete is offline   Reply With Quote
Old 07-31-2008, 12:59 PM   #3 (permalink)
Recruit
koala's Avatar
Thank you so much! i spent a while on the forums looking for an answer with no luck!
Your reply was fast, this forum is awesome!
What kind of tires are you running? Do you see a lot of snow?
Old 07-31-2008, 02:45 PM   #4 (permalink)
neoday's Avatar
Car: 2002 OBW 2.5 manual and character from baseball size hail
Send a message via AIM to neoday Send a message via Yahoo to neoday
search for General Grabber tires and you will get a lot of info.
and welcome!
Love, Laugh, Live
neoday is offline   Reply With Quote
Old 07-31-2008, 04:22 PM   #5 (permalink)
obsolete's Avatar
Yep, I am running a set of General Grabber AT2s to handle whatever weather & terrain is thrown at me up here.
These tires are loud, the sidewalls will roll over if you corner too hard, and they're not great for gas mileage. However, for pure traction in all kinds of circumstances, they're pretty much unbeatable.
Old 07-31-2008, 06:28 PM   #6 (permalink)
Car: 02 Outback Wagon MT in Aus! VibeAWD & 05 Outback in US
Interestingly, the standard tyres on the same year Outback in Australia was 215/60R16. Sidewall height of 129mm. 215/60 R16 95h G-040 YOKOHAMA's
koala's 225/60, have a sidewall height of 135mm, and
obsolete's 215/65/16, have a sidewall height of 140mm (5mm or 0.2" the diff)
then there are tread differences but still I would like what obsoletes tyres on my car!
A fantastic solution to a problem that need not exist!
Aussie Outback is offline   Reply With Quote
Old 08-07-2008, 04:24 PM   #7 (permalink)
Car: 02 outback / 87 supra big turbo / 05 outback xt / 95 4runner 4x4 / 08 cbr600rr
thats good thread we need more info i am planing to run tires that are 27.3" in diameter so i will update if/when i will get them.
stock tires in US were 225/60/16 - 26.6" diameter
stock tires in australia were 215/60/16 - 26.2" diameter
looks like 215/65/16 fits fine with 27.0" diameter (thanks obsolete)
thats a start but if anyone has tried different size tires please let us know so we can update the list. we are looking at tire overall diameter so wheel size does not matter but if you run aftermarket rims please let us know the offset since it is a factor in tire rubing
cheers ziggy
dziuggy is offline   Reply With Quote
Old 08-07-2008, 08:34 PM   #8 (permalink)
Recruit
koala's Avatar
i don't know a whole lot about tire size so i may be wrong but it seems to meet that if both 225/60 and 215/65 fit than is it not safe to assume that 225/65 fit?
Old 08-08-2008, 04:43 AM   #9 (permalink)
well it is not safe to assume but they might fit 225/65/16 are 27.5" in diameter so you will have 1/2" less clearance on all sides and top, so you might have some rubing, but the only way to find out is for someone to try it
cheers ziggy
Old 08-08-2008, 09:25 AM   #10 (permalink)
ggvfr form Australia has fitted Yokohama G011 A/T +11's in a 215/65-16 to fit to 16" steel Forester rims.
I know the Australian Outbacks sit at a different height to the US Outbacks as stock car it its a bit of a guide any way.
