Nokian WR pressure - Subaru Outback - Subaru Outback Forums
Old 09-01-2008, 11:28 AM   #1 (permalink)
Legionairre
Lionel Hutz's Avatar
Car: 02 H6 OB
Default Nokian WR pressure
On my tires it says max 51 psi, the door jam says lower like 29, and 31. Is there a sweet spot in the middle? What is the best pressure for the tires?
Lionel Hutz is offline   Reply With Quote
Old 09-01-2008, 11:51 AM   #2 (permalink)
mslatfly's Avatar
Car: 08 OB 2.5i Basic
Send a message via AIM to mslatfly
Default Re: Nokian WR pressure
The max tire pressure is the highest pressure you can have in the tire without damaging it. It's the NEVER EXCEED pressure, not a safe pressure on a car. And, anything significantly over the recommended pressure can mean poor handling, and loss of control on slick roads.
mslatfly is offline   Reply With Quote
Old 09-01-2008, 03:37 PM   #3 (permalink)
igrf's Avatar
Car: Blue Outback Diesel
The max pressure on the tire wall is indeed the max 'safe' pressure for that tire.
it's however not the best pressure for your car !
car manufacturers design their cars and suspension to work optimal with a specific amount of air in the tire.
So look in the manual that came with your car and run the pressure that subaru recommends.
igrf is offline   Reply With Quote
Old 09-01-2008, 08:45 PM   #4 (permalink)
I'm Not Slash...yet.
FMGreen's Avatar
Car: 2007 Outback H6 LL Bean - Champagne Gold Opal / 2002 Outback Limited - Timberline Green
I run my WRs at 38psi all around.
www.FMGreen.net If you can't keep it clean, keep it green! www.FMGreen.net
FMGreen is offline   Reply With Quote
Old 09-29-2008, 10:22 PM   #5 (permalink)
just passing through
sixfifty's Avatar
Car: 2007 outback 2.5i
Send a message via Yahoo to sixfifty
i like the feel of mine at 34f/32r. if i'm going to be driving strictly on pavement i will go 36/34, but that gets a little squirrelly on dirt or gravel.
i tend to drive more aggressively on unpaved roads, so i keep the pressure a little lower in case i see some dirt i want to try.
looking for a place to happen
making stops along the way
- the tragically hip
sixfifty is offline   Reply With Quote
