winter tire solution for 2006 2.5l - Subaru Outback - Subaru Outback Forums
Old 08-30-2010, 10:33 PM   #1 (permalink)
Default winter tire solution for 2006 2.5l
I just bought this car with 4 season tires on 17 inch wheels. Want to get winter tires and rims . I was advised to get 16 in steel rims and Pirelli Carving ties . Does that sound like good solution
PaulLittle is offline   Reply With Quote
Old 08-31-2010, 07:37 AM   #2 (permalink)
Car: 04 STI, 07 OBW
While you will get a better response in the tire section......
http://www.subaruoutback.org/forums/...es-suspension/
I will say 16" wheels is the way to go. Try to find a set of used Subaru aluminum wheels. You can pick up 16" WRX wheels for $200 for the set.
And for tires, I recomend Hankook iPike409s, or General Artics.
indytruckboy is offline   Reply With Quote
Old 08-31-2010, 09:52 AM   #3 (permalink)
Thanks -both for the advice where to better post the question and alos fo the advice on rims/wheels. This is a large site and and still new to it . cheers
Old 08-31-2010, 01:07 PM   #4 (permalink)
Car: 2003 2.5 4EAT with AWP.
Any used Subaru wheels with a 5x100 bolt pattern will fit just fine. Bang for the buck I think General Altimax Arctic are hard to beat.
Also, welcome to the site. Would you like me to leave this thread here or move it to the Tires subforum?
AWDFTW is online now   Reply With Quote
Old 08-31-2010, 01:44 PM   #5 (permalink)
hi AWDFTW- thanks for advice . And yes ...if you can move thread to the larger Tires subforum that would be great and much appreciated.. I am attemping to review the FAQ for directions on how to do such things but your action would help me right now . Thanks for the welcome
Old 08-31-2010, 02:02 PM   #6 (permalink)
Moved per OP's request.
Old 08-31-2010, 04:58 PM   #7 (permalink)
Administrator
Ignatius's Avatar
Car: 2010 OB Premium CVT Granite Grey
I've said it many times before and I'll say it again...
GO WITH NOKIAN TIRES!
Do a search for "nokian" on this site and you'll find hundreds of posts about how great that brand is, there is no other company that makes a better snow tire. They can be a little pricey but you'll see that they're worth every penny in the end.
Ignatius is offline   Reply With Quote
Old 08-31-2010, 08:50 PM   #8 (permalink)
True, I think Nokian is the best of the best with their winter line. However they are out of my budget range, so I go with "as good as I can afford" most of the time. The joy of being a student again...
Old 09-03-2010, 08:54 AM   #9 (permalink)
Car: 04 STI, 07 OBW
Nokians = too much money
Old 09-03-2010, 06:06 PM   #10 (permalink)
If you want Nokians on a budget, look for their Nordman tire. It is the same tread design as the older Hakkapelita 4, but it is much cheaper than the newer Hakapelita 5 designs.
Pman is offline   Reply With Quote
