215/65/15 vs the stock 205/70/15 will they fit? - Subaru Outback - Subaru Outback Forums
Old 03-23-2011, 07:57 PM   #1 (permalink)
Car: 1997 subaru legacy outback/limited 2.5-5 spd
Default 215/65/15 vs the stock 205/70/15 will they fit?
wanted white letter tires for my 97 outback, not a whole lot to pick from in stock size. what are the pros and cons, going to this size of 215,65,15 if i choose them? looking hard at the bf goodrich ta radial tire. any suggestions related to the fitment of white letter tires of stock size or the 215/65/15 is apprecated.
devesvws is offline   Reply With Quote
Old 03-23-2011, 09:33 PM   #2 (permalink)
Car: 2003 2.5 4EAT with AWP.
Those are smaller than your stock tire, so it would be fine. Speedo will read a little slow.
Old 03-24-2011, 02:32 PM   #3 (permalink)
Banned
TEXN's Avatar
Car: 2007 Outback 2.5i MT
New tire is approximately 1 inch smaller in circumference, and the speedometer will read less than 1 mph faster than you're actual speed.
TEXN is offline   Reply With Quote
Old 03-24-2011, 10:16 PM   #4 (permalink)
Car: 1999 Outback Legacy, AT
215/70-15s will fit, but doesn't look like anything much bigger in overall diameter will fit without rubbing, unless you put on a lift of some kind...
socal1200r is offline   Reply With Quote
