Can this be patched as it's just on the surface or I do I now need 4 new tires? I have 10,750 miles on the OEM Conti-crappers.
Mods: SubaXtreme Nudge Bar, Hella 4000i Rallye Compact Xenon Driving Lamps (HID), PIAA 1500 H3 55W Back Up Lamps, Primitive Skid Plates, Primitive sub-frame and strut-top spacers, King Springs, GT-Spec Front Strut Brace, B&M Auto Trans SuperCooler #70268 & Trans Temp Gauge, 19mm Sway Bar Kit, NRG Lugs, Hella SuperTone Horns, K&N Air Filter, Fumoto Valve, Escort 9500ci, Osram H7 rallye+65 & Philips HIR1 9011 65W bulbs, clear bra, Dynamat, window tint, full chrome delete |
It's not leaking but I know nothing about tire construction. Is it just rubber there that covers the part that holds the air in- or does the rubber that low on the side wall offer structural support?
Dang it.... I already know where this is headed... :
Car: 2003 2.5 4EAT with AWP.
I'd say it is shot.
Options include ordering a new tire from Tire Rack/Discount Tire Direct and having it shaved to match the tread amount on the remaining 3, or upgrade to 4 better tires if yours are 50% or more worn.
Car: 07OBXTL/08LGT.B
Looks like a good excuse to do an all-around upgrade -- that's the sort of damage that can't safely be fixed.
Since you're in Atlanta, think about a set of really good all-seasons. I like Goodyear TripleTreds, but others find them noisy. There are lots of opinions here and at TireRack. HPH |
Thanks. I'm hoping to move to Seattle soon and I would also like something a bit more heavy duty for off-roading.
I am currently thinking about these: GEOLANDAR A/T-S Off-Road Performance Tires | Yokohama Tire Corp. They come in stock 225/60 R17, or one size up to 225/65s - would love to go bigger but am worried about clearing the spring perches. ![]() ![]() ![]() Any thoughts?
Car: 2006 Subaru Outback Wagon 2.5L H-4cyl. Auto
You should not and can not patch a sidewall on a tire. NOT safe! And they will not do a sidewall patch in most states. Even the manufacture does not recommend. Most tire sidewalls are only two ply.
It is what it is!"06 Outback 2.5i |
#8 (permalink) |
Car: 2011 Outback Limited
Too bad about the tire but its not repairable. Crappy Conti or not, sidewall damage like that can happen with most tires against a sharp curb or rock. Consider yourself lucky to have spared the nice powder coated rim from damage.
#10 (permalink) |
Thanks! I will definitely take you up on that!
