limited slip differential - Page 3 - Subaru Outback - Subaru Outback Forums
 1Likes
post #21 of 100 (permalink) Old 09-14-2007, 02:54 AM
Car: 2001 Outback Limited
I have the 2001 LTD so it also have the rear lim-slip diff, do I need to be using special limslip gear oil for the rear and normal hypoid gear oil for the front?
It doesn't say in the manual?
One thing it does say in the manual is tht brands of oil should not be mixed, so does that mean I shouldn't refill with different brands without some kind of a flush or only that I shouldn't top up?
Something profound.
OzzyOutback is offline
post #22 of 100 (permalink) Old 09-17-2007, 02:04 PM
Car: Subaru:'07 3.0R LLBean, '01 H6 LLBean, '00 BRP 2.5RS. As well as 10 other cars and 9 motorbikes.
a good idea would be installing a 1.5 way clutch-type limited slip differential such as one from Deftforce or Kaaz... the VLSD usually ends up getting worn out.
we usually refer to the stock nissan VLSD as V-open.. basically when it's worn out.. it might as well be open.
quazar is offline
post #23 of 100 (permalink) Old 09-17-2007, 02:50 PM
Car: 01 H6-3.0 W
can you have torque bind with an VLSD?
mtlsuby is offline
post #24 of 100 (permalink) Old 09-18-2007, 11:44 AM
Zap
Zap's Avatar
Car: 013 XV
Do you understand the concept of Limited Slip Differential?
Some Subarus I've owned: http://community.webshots.com/album/37919799NGXlOA
Zap is offline
post #25 of 100 (permalink) Old 09-18-2007, 12:30 PM
Car: 01 H6-3.0 W
mtlsuby is offline
post #26 of 100 (permalink) Old 09-18-2007, 12:58 PM
On the newer soobies, they use the ABS in conjunction with a traction control to give you "lockers" on all front wheels. The computer basically applies the brake's to the wheels that are slipping. This transfers power to the wheel's that are not slipping (have traction). As long as you have one wheel with traction, you won't get stuck.
On older soobys, you can almost do the same thing if you have an automatic. You lightly apply the brakes while giving the car gas. On manuals you can apply the parking brake slightly (not allowing it to latch.)
nipper
*edited by boxxerace
nipper is offline
post #27 of 100 (permalink) Old 09-18-2007, 01:58 PM
Gallery Ninja
Boxxerace's Avatar
Car: 2004 Outback "Bluebaru" & 2005 Outback XT
Torque bind will generally result from a worn or locked up center differential. Side to side tire drag can happen with full lockers, but never with a Limited Slip. There is just not enough side-to-side grip by the limited slip to prevent the tires from rotating at different speeds.
To give you an illustration, in the snow driving that I have done, I have found I will get stuck on a snowy hill as the wheel on the right side spins and digs in and the left one just stays there motionless. It is eternally frustrating to someone who own's a vehicle with lockers.
Ancient moderator of color and bokeh. Boxxerace Outback Gallery:
Boxxerace is offline
post #28 of 100 (permalink) Old 09-18-2007, 03:05 PM
Thats not true. Limited slip differntials are the same viscous unit thats in the center diff of a manual tranny. you can destroy them by having miss matched tires left and right.
There are basically two types of LSD (three including computer operated clutches). The mechanical units use either a clone clutch, a clutch pack, or the extreemly complicated haldex (torsen).
http://www.torsen.com/products/T-1.htm
http://auto.howstuffworks.com/differential4.htm
http://auto.howstuffworks.com/differential5.htm
The other type is the viscous unit. The Older style (cone and clutch pack) are always transfering power to both wheels equally no matter the conditions. When the car turns, one wheel spinng faster then the other will overrun the clutches and disconnect one wheel from the power. The mass and traction of the tire is transmitted to the clutch springs. This is wny positraction is great in straight line acceleration, trailer towing, etc, but can be a little dicy in snow and ice. With snow tires they are great, and unstopable with studs.
A viscous coupling is a differential waiting for slip to happen, unlike the mechanical units. When one wheel starts to spin faster then the other, the fluid heats up, expands, and "connects" both axles. Another veriosn of this has the fluid inside a piston, and when it expands it engages the clutches.
You can destroy either LSD with mismatched tires. The advantage to the VC over the mechanical is a better feel in turns (as they age the mechnaical can become grabby), and less drag so better gas mileage, and less weight (less parts cheaper to make). The disadvantage is that a wheel has to start to spin for it to operate.
Torsen is best suited for performance cars. Both wheels need to have traction in order for it to function. If either wheel looses all traction, it wont shift power. A torsen can be designed to multiply the torque sent to the wheel with more traction. Most torsen differntials have a manul differnetial lock because if it looses traction, just the one tire spins.
You can see how a mismatched tire can burn out any LSd (though I am not sure about the torsen yet).
Lockers are a completly differnet animal. They override the function of the differntial and lock both wheels together. One can argue in this mode that its really not a differntial.
nipper
nipper is offline
post #29 of 100 (permalink) Old 09-18-2007, 03:26 PM
Gallery Ninja
Boxxerace's Avatar
A spool eliminates the "differential", however a locker does allow the inside or outside wheel to rotate at different speeds. A detroit locker tends to lock the wheels together only while on the throttle. Goofy for the street and bad for your tires, but if you coast or stay off the gas somewhat the locker "un-locks" and allows you to turn without dragging your tire.
Edit: I'll add that my experience with the LSD is mostly with our manual tranny OBXT. It never binds and always "one wheel spins".
post #30 of 100 (permalink) Old 09-18-2007, 03:46 PM
http://www.offroaders.com/tech/limit...ferentials.htm
Really good explinations.
nipper
nipper is offline
