grabbers and chains - Subaru Outback - Subaru Outback Forums
Old 01-02-2010, 01:33 PM   #1 (permalink)
Sario's Avatar
Car: 1997 outback limited. 249,000 miles and counting
Default grabbers and chains
OK so i know 205/75R15 Grabbers will fit under the first generation outbacks. But has anyone tried running them with chains?
Sario is offline   Reply With Quote
Old 01-02-2010, 01:46 PM   #2 (permalink)
bikemobile's Avatar
Car: 05' OB 2.5i
Default Re: grabbers and chains
I dont think there is enough clearance around the tires between the inner sidewall and the struts/balljoints. Most newer trucks and SUVs cant even run conventional chains.
Cables are what is recommended for even the first gen outback.
I did see some small link chains the other day at the hardware store.
I would look and see how much room you have between your tires and the front steering suspension components.
bikemobile is offline   Reply With Quote
Old 01-02-2010, 02:02 PM   #3 (permalink)
Sario's Avatar
Default Re: Re: grabbers and chains
opp! I'm not sure why i wrote chains. I was THINKING cables. I know chains wont fit, they dont even fit on stock size tires. I was trying to find out if cables would have enough clearance on the 205/75R15 tires.
thanks
Old 01-02-2010, 02:19 PM   #4 (permalink)
bikemobile's Avatar
Car: 05' OB 2.5i
Default Re: Re: Re: grabbers and chains
thanks
Crank the wheels both ways and look in the wheelwells. Cables are usually 1/8" or so.
Old 01-02-2010, 02:45 PM   #5 (permalink)
Sario's Avatar
Default Re: Re: Re: Re: grabbers and chains
I Don't actually have grabbers on my car. I was going to go pick up a set on Monday, if i could use cables with them. I just have some 205/70r15 all-seasons on the car now. I'd like some tires that work a little better in unpacked snow. If i cant use cables on the grabbers, I'd be better off with the all seasons though.
I'm hoping someone here is running the grabber at2 on a first generation, and has tried to use cables.
Old 01-02-2010, 07:08 PM   #6 (permalink)
daredevil1166's Avatar
Car: '99 Outback Limited, 2" Lift, 28" AT's, Winch, Dual-Range 4wd.
I didn't actually use them, but I test fitted cables to the front tires after I got my AT2's.
I've used chains with them but that's been after I lifted the car. I only test fitted the cables before the lift. They went on and it looked like they would work.
I guess I can't say for sure though.
daredevil1166 is offline   Reply With Quote
Old 01-03-2010, 10:37 PM   #7 (permalink)
Sario's Avatar
Thanks for the info. I would just order the tires and find out for myself, if there was somewhere I could order some springs to lift my car. It would be nice to have a backup plan.
Old 01-03-2010, 11:01 PM   #8 (permalink)
I just used strut spacers to lift mine.
If you want to do that let me know. It's a super easy way to lift these cars, and fairly inexpensive.
Old 01-03-2010, 11:28 PM   #9 (permalink)
Sario's Avatar
Really? did you make them yourself? I am very interested!
Old 01-04-2010, 03:11 PM   #10 (permalink)
I had them made. I'll PM you a little more info.
