AWD durability soft-roading (sand) - Subaru Outback - Subaru Outback Forums
Old 08-10-2011, 11:17 AM   #1 (permalink)
Default AWD durability soft-roading (sand)
I got to thinking, after reading through this section, how durable is the AWD/clutches in this thing? I do a lot of sand soft-roading here and the AWD would be working a lot compared to a proper locked transfer case. My biggest worry is heat. The biggest fan assisted trans cooler I can fit on it will help with the tranny, but not sure about the rest of the system.
They do 250km desert fun drive here across the desert that we do, I know the Outback will not have any problems with the terrain, but not sure how the AWD will hold up mechanically. The event is held over 2 days so it not a straight 250km's and a lot of its on sand track, but the AWD will be working. Its done in January so the the weather is cooler.
Reading here, most just do a little sand soft-roading for not very far.
Thoughts ......
Chris
09 Ruby Red Legacy B-Sport 2.5i
12 Outback 3.6R - still waiting!
ZsSubie is offline   Reply With Quote
Old 08-10-2011, 11:37 AM   #2 (permalink)
Thoughts ......
Chris
Chris my understanding of any limited diff or for that matter AWD system is that any surface that allows tires to slip greatly reduces the loads and friction on the AWD system. It's the pavement where tires do not slip that causes the issue given the tires do not slip when one loads up more than the other thus putting a high strain on the drive bits and clutches. I wouldn't worry about it pavement and no slip is the biggest issue. For you it will be tire durability and having a low energy exit strategy for getting stuck.
Old 08-10-2011, 03:54 PM   #3 (permalink)
rockhopjohn's Avatar
I don't think you'll have problems, I have done my share of soft roading, and my car has held up quite well. One thing you will want to remember is that all of the stuff that transfers power back and forth is in the center diff, which uses gear oil, and in the case of the AT does not communicate with the AT fluid in any way. This gear oil is much more robust than ATF, and in this application doesn't get too hot, and never gets into temp ranges that make it susceptible to break down by heat.
Old 12-07-2011, 09:16 PM   #4 (permalink)
Outback onsight...
Scooby's Avatar
Car: '03 black/blu BH ,kings ,sutble,bfg A/T's, '98 forester S, 4eat, lsd
Default at and sand
Autos work great in sand...Get a trans cooler a small one is all you need..
I run sythetic which deals with heat better than regular atf.
I've run alot of (wot)
hard miles on the sand with no problems..
Manual trans.
Don't as well do to higher gearing and stock clutches I've seen burned up easily.
Get an aftermarket stage one exedy clutch. If your gonna tear it up..
Note: If your burn the clutch out there..let it cool down for 20min or so It should get ya home..Smells bad ..
It will be time for a new one..
OutbackwBeer!
" T' were worth ten years of peaceful life, one glance at this array."
Scooby is offline   Reply With Quote
Old 03-07-2012, 10:46 AM   #5 (permalink)
Scooby, any particular transmission cooler you recommend?
AoD915 is offline   Reply With Quote
Old 03-07-2012, 09:03 PM   #6 (permalink)
Outback onsight...
Scooby's Avatar
Default hayden trans cooler
Hayden makes a good cooler. However, I'm not partial to any brand.
Just measure the area the area you have to fit one in. It doesn't have to be big at all . If you were towing like an F350 that's another story.
OutbackwBeer!
Old 03-08-2012, 08:22 AM   #7 (permalink)
Car: 2008 Outback 2.5i
I believe the center diff uses AT but the front diff uses separate gear oil.
arthuruscg is offline   Reply With Quote
Old 03-08-2012, 09:37 AM   #8 (permalink)
jp1203's Avatar
Car: 04 Outback H6 L.L. Bean Wagon
I wouldn't worry about it. Just the fact that there are tons of Subarus up over 200k that have never had any issues with the AWD speaks for itself. Maybe even most of them that make it that far never have AWD issues...it's a fairly bullet-proof system.
2004 Silver Stone Metallic Subaru Outback H6-3.0 L.L. Bean Wagon - JVC KW-HDR720 Headunit - Rallitek Skid Plate - Rally Innovations Light Bar - PIAA 540ATP Driving Lights
Old 03-09-2012, 12:39 AM   #9 (permalink)
LosAngelesLGT's Avatar
Car: 05LGT unltd RBP 5mt Stage3.5 359whp/425wtq + 06 OBXT BSM/GGO 5mt ltd. + 1999 Dodge Durango Modded Towpig & 19' Airstream CCD
DO NOT GET AN EXEDY STAGE 1 CLUTCH UNDER ANY CIRCUMSTANCES.
It is loathsome
It is stupidy heavy
It chatters badly
It modulates poorly
It has a cheap POS throw out bearing
CLUTCHMASTER feels stock and is better
COMP is way better still
Ive had a few different clutch setup in an 05-09 LGT/OBXT
LosAngelesLGT is offline   Reply With Quote
Old 03-09-2012, 02:56 PM   #10 (permalink)
highest_vision's Avatar
Car: 02 Outback 2.5 5sp
It is loathsome
It is stupidy heavy
It chatters badly
It modulates poorly
Perhaps they are different for 05+. I have an Exedy in my car, for 30k or so. It is no heavier than stock. It does not chatter. It engages fine. I used a different throwout bearing that is for use with a quill, no comment.
James
highest_vision is offline   Reply With Quote
