Taking a 97 outback but I wonder about how many times would I need to fill up? it's about 648 miles where I'm going one way.. I was guessing around maybe 3 1/2 times?
I'm not sure how much you can get from the tank with the 2.5 motor |
Car: 2003 2.5 4EAT with AWP.
Depending on where you set your cruise control you should be getting 26-28 MPG. Could make just shy of 400 miles per tank in the old 1996 with cruise set at 60-65.
2003 Outback: "Kaylee". 108k and counting. +30 low beam upgrade, HIR1 high beam upgrade, Nokya yellow fog lights, Fumoto valve, Quaker State Ultimate Durability 5w30, PureONE oil filter, STP air filter, Valvoline Maxlife ATF, Valvoline Durablend 80w90, Michelin Primacy MXV4. Also: more rust than I care to think about. |
Car: 2001 Outback, Blue/tan, 5 speed manual
gas is $4.29 in Michigan right now. It was noticeably cheaper in Ohio, try to top it off there before you get to the Mitten. What are you doing in Michigan?
KzooSubaru '01 OB, 5 spd |
