Changing Front Differential Fluid. Automatic Transmission - Page 2 - Subaru Outback - Subaru Outback Forums
 3Likes
post #11 of 101 (permalink) Old 08-20-2009, 11:39 AM
I've heard this is a good cocktail mix for front and rear diffs ('98 OB)
3 units X Redline 75W90NS (75%)
1 units X Redline Shockproof Lightweight (25%)
For the Rear Diff: use Redline Shockproof Heavyweight (vs. Lightweight)
bobmac99 is offline
post #12 of 101 (permalink) Old 08-20-2009, 01:24 PM
Car: 04 Outback H6
I'm pretty sure that cocktail mix is for manual transmissions as it's almost 2 quarts too much.
On the Auto transmission, the front & rear diffs combined take a little over 2 quarts.
weldonjr2001 likes this.
kmltick is offline
post #13 of 101 (permalink) Old 08-20-2009, 02:16 PM
Button's Avatar
Car: My-'06 Outback 2.5 i Limited Wagon & Wife's '08 Outback 2.5 i Limited Wagon
Send a message via AIM to Button
bobmac99,
Cocktail(s) are alcoholic beverages for people not for cars.
Regards,
~Button
I yearn for Portsmouth & the White Mountains!-!-!
R.I.P. '04 Gas Swillin' Chevy Hoe
Button is offline
post #14 of 101 (permalink) Old 10-28-2009, 03:54 PM
Car: 2002 Outback LTD Wagon
He said 3 PARTS and 1 PART NOT 3 QUARTS and 1 QUART. 1 part can be 1 oz 1 cup 1 litre, just divide the TOTAL amount neede by 4 and that is your 1 part equivalent.
Steve
'02 OBW Limited
mrbeal is offline
post #15 of 101 (permalink) Old 01-25-2010, 05:12 PM
My 06OBXT seems to indicate that changing the diff oil is not required ?
Is this correct ?
mhyne is offline
post #16 of 101 (permalink) Old 01-26-2010, 03:18 AM
Is this correct ?
If it's a manual transmission then that's correct - the front differential shares it's lubrication with the gearbox itself.
If it's automatic transmission then the front differential has it's own oil sump/dipstick and uses GL-5 gear oil, not like the ATF-HP for the auto gearbox.
Ruperts Trooper is offline
post #17 of 101 (permalink) Old 01-26-2010, 11:18 AM Thread Starter
Brucey's Avatar
I think the manual does state for certain things that the oil is good for the life of the vehicle.
The problem I see with that is "The life of the vehicle" means "Until the Warranty runs out"
I'm at 120K miles and ticking. I don't even remember ever having a warranty. (:
Brucey is online now
post #18 of 101 (permalink) Old 02-05-2010, 06:18 AM
Car: want to get a 2010 Outback with CVT
Thank you gentlemen, your posts were most informative.
Did anyone identify the thread size of the drain plug, please? Is it M20 X 1.5 ? The same as the engine oil drain plug?
Thank You
"You don't have to see the whole staircase, just
take the first step"
MrDimple
.com
cell: 704.320.0700
MrDimple is offline
post #19 of 101 (permalink) Old 03-09-2010, 10:37 AM
8kGoodENuff's Avatar
Brucey,
Did you use an extension on the socket wrench to get the drain bolt undone? It seems that it is kind of tight in there with just the socket and wrench.
Thanks,
Andre
2006 Honda S2000 (Good Weather Warrior)
1998 Subaru Legacy Outback (Extreme Weather Warrior)
2012 Subaru Forester 2.5X Premium (Wifey's Ride)
2015 VW GTI S Performance & Lighting Package (Finally Some Torque)
2013 Super Cycles Scooter: 1500-Watt Brushless Motor (702 MPGe... Ohhhh the savings!!)
8kGoodENuff is offline
post #20 of 101 (permalink) Old 06-06-2010, 10:39 PM
Car: 2006 Outback 2.5FI
For those looking for a T70 Torx bit, I found mine at Autozone for $3.99.
barontynan is offline
