DIY front cv axle & boot replacement - Page 3 - Subaru Outback - Subaru Outback Forums
LinkBack Thread Tools Rating: Thread Rating: 5 votes, 4.20 average.
Old 05-24-2010, 12:54 PM   #21 (permalink)
Brucey's Avatar
Car: '00 AT
I disagree.
It takes no special tools, its more of a trouble to get the axle off than it is to repair the boot because of the cotter pin and finding a punch that will fit it. Really all you need that wouldn't be needed for replacing the axle is a pair of needle nose pliers and something to cut the boot with.
It's not a clean job, getting underneath the car that has 50K+ (Earliest I remember seeing them tear) real world miles is going to be filthy. Even if you spray off the undercarriage first, you're still going to need a shower after. The grease in the boot is sticky yes, but if the boot is torn (why you're replacing it) its mostly everywhere but inside the boot. Its all over the engine bay and you might as well clean that up too while you're in there.
There's no real servicing needed of the axle itself. As long as its not clicking it shouldn't be a problem. My axle boot was torn for 3000 miles at least and the bearings were all good, no marks or anything broken otherwise.
It only ads about an extra hour of time versus replacing the entire axle. And thats if you don't know what you're doing. But it saves roughly 100$. (Assuming MWE axles, which seem to be the cheapest option that don't have vibration issues. 75$+ shipping + core, assuming you get the core charge back too.) I dont make 100$ an hour so it seems the best route.
I guess to each his own, but the big thing I worry about when replacing an entire axle is the wheel vibration most people seem to get. I've known 3 people with Subaru's who replaced their axle with a cheap one and all 3 of them have had wheel vibrations ever since.
I do agree with the recycling though. I keep all my nasty junk in a weatherproof container in the garage and bring it to the recyclers when its full.
Cheers
Daily Driver
Winter Beast
Old 05-24-2010, 01:01 PM   #22 (permalink)
Originally Posted by Brucey View Post
Why is everyone replacing the entire axle for a torn boot? It seems kinda over kill to me. You have to also consider unless you get a very good axle there is a good chance its going to have vibration problems.
Because they don't know any better. Unless the joint is showing obvious signs of problems clicking when turning etc chances are its fine and just needs a new boot. Not to mention replacing your known drive line with an unknown recycled drive line is sort of like playing the lotto you might get a true drive line or you might get someone elses problem drive line and you just swapped your good one for a bad one because a rubber boot failed :-) oops
subiesailor is online now   Reply With Quote
Old 05-25-2010, 09:31 AM   #23 (permalink)
Car: 2002 OBW 2.5L 4EAT
I went for a replacement driveshaft because I'm at 160k now with everything stock, and I believe the boot had also been split for a while before I noticed it. I also just got an OEM reman, since this car is only 8 years/160k miles young, and I have no plans to rid myself of it anytime soon.
I digress, though. Not a quick job if you live in the Northeast or somewhere similar! Everything is completely rusted solid, and that broken bolt is a huge PITA. Drilling it out didn't go so well, so I'm going to try to throw it on a mill and use an end mill to try to take the bolt out. Then comes the problem of the ball joint that's rusted in there. Brute force should solve that one though.
dpraetorius is offline   Reply With Quote
Old 05-28-2010, 03:53 AM   #24 (permalink)
driveby's Avatar
Car: 2001 OBW H6 VDC
I guess to each his own...
Exactly. Like I said in post #1:
Originally Posted by driveby View Post
If you're considering a reboot only, first read these End Wrench articles on Drive Axle Service and Subaru Remanufactured Axles. If you can afford (time & money) to reboot your own axles, go for it!
Each of us has to make his/her own decision about the acceptable level of maintenance on our vehicles. Just me...I want everything done to factory standards. And there are several dozen steps & gotchas to inspect & reboot an axle to factory standards...specific types & amounts of grease, amount of air in the boots, torque on the bands, matching of each free-ring with its own slot in the outer race, etc, etc. It would take me far too long to do all this stuff myself. I'd rather leave this to the experts who rebuild axles every day, with ISO quality assurance procedures.
Also...rebooting is not free. You still have to buy the boot(s), special grease(s), band(s), solvent, a new axle nut, perhaps a new roll pin, and perhaps a banding tool (unless you can evenly tighten a band to 100+ ft-lbs with your pliers). When you add it all up, an MWE reman doesn't cost much more.
I do agree about the "recycled axle lotto" though. You have to consider the source of the axle, and the timing wrt your model year and mileage. In my case and dpraetorius's case, the OEM remans that we used were almost certainly newer and better than our old axles.
The OEM remans come from Subarus only and are refinished/rebooted just once. Chances are, these axles came from cars that went to a dealership for 60K maintenance, or just an oil change, and they were swapped because of a tiny hole or leak. Not a monster gash like the one I had.
-Jeff
p.s. The roll pin does not require a pin punch. You can tap it out with a 3/16" drill bit or a #6 (20p) nail. A pin punch is handy b/c you can also use it to unstake/stake the axle nut...but a chisel does that job just as well.
driveby is offline   Reply With Quote
Old 05-28-2010, 10:56 AM   #25 (permalink)
Brucey's Avatar
Car: '00 AT
Really? I had such a pain of a time with a drill bit. And a nail.
They kept going through the center and getting lodged. Did they change them to non hollow ones at some point?
Daily Driver
Winter Beast
Old 06-02-2010, 03:08 AM   #26 (permalink)
driveby's Avatar
I love your style Brucey. You know I know you know.
For everyone else: Use the flat end of the drill bit. Or a #6 nail with the head or tail cut off.
Or just buy a 3/16" pin punch. I got mine at Sears for less than $2. Not Craftsman, not a set, just some loose no-name punch on the bottom shelf. Even cheaper than Harborfreight, wow. And it did double-duty for the roll-pin removal and axle-nut peening.
-Jeff
Old 06-02-2010, 10:25 AM   #27 (permalink)
Car: 2012 2.5i
just did both fronts on my wife's 05 LL Bean. Used MWE axels, great axels and great to deal with too! only trick/trouble I ran into was getting the lower ball joint disconnected. No rust problems with the pinch bolt, but I had to remove the castle nut on the bottom to get it all separated. Also, for those of you who have a male end on both sides of the axel, it is $100 more per axel from MWE ($195 ea).
dprice is offline   Reply With Quote
Old 06-02-2010, 10:59 AM   #28 (permalink)
Brucey's Avatar
Car: '00 AT
Haha, I was using the flat end of the drill bit. It was still going through it. Maybe my drill bit set was mislabeled though, I have several and I'm sure over the years the main one has had mismatched sets put together.
Daily Driver
Winter Beast
Old 06-02-2010, 12:29 PM   #29 (permalink)
driveby's Avatar
Hehe. My advice, the next $20 you spend on tools should be for a dial caliper.
Never again will you have to guess the size of a bit, bolt, screw, pin, washer, o-ring, shim, pipe, tube, disc, etc etc. Just whack the caliper on it and you have your answer.
-Jeff
Old 07-29-2010, 03:00 PM   #30 (permalink)
skinheaddave's Avatar
Car: '03 2.5 Outback
Originally Posted by dpraetorius View Post
GAH! The head of the @&$#ing pinch bolt broke off, and eight hours of attempting to drill it out led to the extractor breaking. Gonna try to get a machine shop to drill it out for me tomorrow, as well as pull out the ball joint from the knuckle. Everything is just completely rusted solid.
I'm now in a similar position. I haven't broken the bolt head yet but no combonation of heat/penetrating oil/hammering/wrenching etc. seems to be able to budge it.
Question: Is it possible to remove the nut underneath the ball joint and remove the entire post from the suspension arm without removing it from the pinch joint?
Cheers,
Dave
skinheaddave is offline   Reply With Quote
