Changing Automatic Transmission Fluid (is easy) - Page 35 - Subaru Outback - Subaru Outback Forums
Old 10-29-2012, 07:06 PM   #341 (permalink)
Car: 2011 Prem. 2.5i, 1999 Outback
Yes they are expensive, but fortunately don't have to be changed too often, if at all. Most dealers don't change it even when doing a drain and refill of the ATF.
Glad it was resolved quickly . . . enjoy.
He is right, most dealers dont change those filters unless damaged.
I got one from a dealer,( I think around $35). I did not use it, just took it back to dealer. I only changed out ATF several times, (about 4), and tranny works fine. This Outback has 175,000 miles on it.
linkbelt1 is offline   Reply With Quote
Old 11-11-2012, 03:07 PM   #342 (permalink)
Car: 2007 OB 2.5i
I bought a 2007 OB 2.5i automatic with about 90k miles a few months ago. It now has about 100k mi and has developed a clunk when shifting into third when cold. I am hoping ATF flush will make all the bad stuff go away.
I will be doing the technique where the line delivering ATF to the radiator is disconnected. There are two versions of this technique illustrated in this thread and elsewhere on the net. One version does not drain the pan, the other does. What is the science on this? Does the ATF in the pan get cycled and changed naturally with the complete flush technique? It seems like it would have to. Is there another reason to remove drain plug?
I will be changing the spin-on filter.
bcRock is offline   Reply With Quote
Old 11-12-2012, 10:26 AM   #343 (permalink)
If I understand the flow right, when you add fluid it goes into the pan. I drained just over 4 quarts from it -- so if you don't drain/refill it to start it with fresh fluid, it will take a lot more fluid to flush it clean. Pulling the plug is the easy part anyway, so I don't see any reason not to do it.
BrianB is offline   Reply With Quote
Old 11-12-2012, 09:14 PM   #344 (permalink)
Car: 2007 OB 2.5i
I could not find a fluid flow diagram for this or any other Subaru. I did find two diagrams for other cars and both showed the flow from pan to cooler. If this is the case with my car I would not want to drain and fill pan before I start engine because the new fluid would be the first to go into my discard container.
Old 11-13-2012, 06:54 AM   #345 (permalink)
I don't think the flow is from the pan to the cooler. In a thread about the ATF filter, I tried to better identify the flow in order to determine the role, and impact, of the filter.
Earlier service manuals had some hydraulic schematics which were somewhat helpful. There's attachments in this post: hydraulic circuit.
Old 11-13-2012, 10:58 AM   #346 (permalink)
If I remember right the cooler is last before the pan but I did this a while back now. I flushed it this way on the 4EAT and it worked great, and will do it again in a couple years.
Old 11-23-2012, 03:05 PM   #347 (permalink)
Car: 2007 OB 2.5i
Flushed the ATF in my 2007 2.5i OB yesterday. The line connected to passenger side of radiator is the return Line. This line is rubber for the first couple feet exiting the radiator and metal the rest of the way bact to the xmission. I broke the connection at metal/rubber joint. Simple hose clamp. This way I could easily reroute the rubber line into my collection container.
Procedure:
Drain pan,
Replace spin-on filter,
Fill pan,
Disconnect rubber hose returning from radiator and reroute to collection container (see above),
Start engine - shift through all gears w brake on - 30 seconds max - stop engine,
Add ATF until full,
Discard old collected ATF,
Repeat start engine/fill sequence until 12 qts used. The xmission only holds 9.7 qts. I wanted to make sure I got the whole mix as clean as possible.
I did not measure anything. Just made sure I didn't run engine too long.
My original symptoms were rough shifting when engine cold, especially going into 3rd. Another symptom which I did not attribute the the xmission was no response and downright funk starting from a stop.
Starting with the very first test drive and my driving today all symptoms are GONE! Even taking off from a stop. I may just keep this thing. I will post if anything changes.
Old 11-30-2012, 09:59 PM   #348 (permalink)
Car: 2013 Outback 2.5i Premium
I believe your assessment of our President puts you in the minority of Subaru drivers, at least in my neck of the woods. I'm on board with you though brother!
5outbacks4jon is offline   Reply With Quote
Old 11-30-2012, 10:44 PM   #349 (permalink)
Car: 2003 2.5 4EAT with AWP.
...I don't think this post is in the correct thread.
Old 01-26-2013, 12:38 AM   #350 (permalink)
Car: 2005 XT Limited
Just used the directions for the ATF flush using the return line from the cooler for my 2005 XT (5EAT). I put my comments on that thread, but I think it will be useful for most:
http://legacygt.com/forums/showthrea...sh-197248.html
One comment on whether to drain the pan: after thinking about it, I realize I should have drained the pan. Since it holds 4 qts, when you empty the first two, you are then adding two new quarts to two old quarts. Probably better to drain, and start with 4 fresh in there.
tdelker is offline   Reply With Quote
