Subaru Outback front shot by group member my04inoz
Welcome to the Greatest Subaru Outback Resource!
We proudly serve the Global Subaru Owners and Enthusiasts Community!
Home Forum Index Member Galleries Chat Games Dealer Rating Archive Terms of Use Contact Us
 Control Panel     Register       Members      New Posts    Adv. Search  Questions? Search our Forums:
SUBARU OUTBACK : Powered by vBulletin version 2.2.8 SUBARU OUTBACK > General > Do-It-Yourself Illustrated Guides > Lifting and supporting points
Last Thread Next Thread
Author
Thread Post New Thread Post A Reply
The_Lizard
Tokyo's between my toes
Car: 1996 Glacier White Outback 5MT
This is the OEM rear skidplate on a 98 OB. It can be used as a lifting point, with a floor jack.
The_Lizard has attached this image:
Report this post to a moderator | IP: Logged
Old Post 09-17-2006 04:24 PM
The_Lizard is offline Click Here to See the Profile for The_Lizard Click here to Send The_Lizard a Private Message Find more posts by The_Lizard Add The_Lizard to your buddy list Edit/Delete Message Reply w/Quote
The_Lizard
This is a jackstand spanning the pinch weld at the rear of the 98 (right side). My general rule for supporting the rear of a body is to place the stand near the point where the control arm attaches to the body.
Old Post 09-17-2006 04:26 PM
aerosaaber
Paladin
Car: 01 OB Wagon Limited 5spd
quote:
If I remember correctly the jackstands are located at the bushing area for the lower control arm. My jackstands have the curved surface you describe, definitely not for use with a pinch weld. I've used this type of point on my other cars in the past. Because the bushing area of the car is strong enough to deal with lots of stress, placing a jack stand there shouldn't be a problem.
I don't have any better pics of this location, hope that's good enough for now.
Also once you install a skidplate like this one, you'll still be able to jack the car from the center jackpoint, located just behind the two bolts at the back of the skidplate.
Old Post 07-04-2007 04:09 AM
aerosaaber is offline Click Here to See the Profile for aerosaaber Click here to Send aerosaaber a Private Message Find more posts by aerosaaber Add aerosaaber to your buddy list Edit/Delete Message Reply w/Quote
OzzyOutback
Legionairre
Car: 2001 Outback Limited
Hi guys,
I have some Jack Stands that I want to use to lift up my front end however they are only rated for 1,200kg's each and I believe the cars gross weight is 2,066kgs.
What I would like to know is, the front end weight is 1,002kgs, so will tthis be ok for the stands or should I get stands rated for the gross weight?
Secondly, when jacking up the car with the emergency jack for the stands, do I need to keep the jack in the center of the pinch-weld or can I jack it up anywhere on the weld so I can put the stand on next to it?
This brings me to my last point, is it OK for the car to be jacked up on one side and placed on a stand, then jacked up on the other, or does it need to be jacked from the center to prevent stress?
Something profound.
Old Post 07-28-2007 08:00 AM
OzzyOutback is offline Click Here to See the Profile for OzzyOutback Click here to Send OzzyOutback a Private Message Find more posts by OzzyOutback Add OzzyOutback to your buddy list Edit/Delete Message Reply w/Quote
aerosaaber
Paladin
I believe the jack points along the pinch weld are specific so I don't think you can "jack anywhere" on the pinch weld.
I don't know about jacking one side and then the other, I have always just gone from the middle.
If you look for a floor jack you should be able to find something that isn't too expensive. I see sets of jack and 2 jackstands for under $50 all the time.
Hope that's helpful.
Old Post 07-28-2007 03:00 PM
The_Lizard
Side to side can be done, that was the only way I could lift the Escort.
Ozzy, I think you are well within a safe limit - assuming that load is approximately half the rated capacity.
Once I set the car on jackstands, I like to grab it and give it a shake to make sure everything is settled. Better to find a problem then than to be under it with a wrench, pulling hard...
Old Post 07-28-2007 08:23 PM
OzzyOutback
Legionairre
Ok, thanks fellas.
Something profound.
Old Post 07-29-2007 06:35 AM
The_Lizard
Today I lifted the front of the 96 to go after an exhaust shield rattle. I noticed that the pinch weld has old damage from being either lifted or supported incorrectly. So here's a shot of doing it right, next to evidence of doing it wrong.
Old Post 08-17-2007 07:58 PM
The_Lizard
Lifting the front of a 96 2.2, w/o skidplates. In the past I've lifted by the forward crossmember, but this time I cradled a longitudinal plate (black in this pic) that spans between two crossmembers. The engine did not go through the hood.
Old Post 08-17-2007 08:11 PM
aerosaaber
Paladin
Lizard that is the exact place I use to jack my car, only with my skidplate on, it's covered. So I just jack against the skidplate that sits flush against that plate which IIRC is the "jack plate" or something like that in the parts manual.
When I got the skidplate the actually sent me one of those, Perhaps some other them did not have threaded holes for the bolts used to secure the skidplate?
I just reused my old one which appears to be stouter with multiple layers of steel.
Old Post 08-17-2007 11:11 PM
eno
Legionairre
Car: 2003 OBW & 2000 OBW Limited
Can anyone confirm if this is the correct spot on my OBW 2003. Do I center the jack on the plate itself or should I try to devide up the lift point with the main bar that the plate bolts to?
And for the rear, is the rear diff truly a safe point to my jack? I am that type that seems to screw stuff up so I just have to double check.
eno has attached this image:
Old Post 09-05-2007 04:37 PM
eno is offline Click Here to See the Profile for eno Click here to Send eno a Private Message Find more posts by eno Add eno to your buddy list Edit/Delete Message Reply w/Quote
mikebike357
Paladin
Car: 2008 Outback 2.5i 5MT
^^ that's the spot where I have lifted a:
97 Outback Sport
98 Outback Sport
02 WRX
03 Forester
04 Forester
04 WRX
05 STi
and when the time comes, a:
08 Outback
I put a hockey puck on my floor jack to pad the jack where it meets the undercarriage. Works like a champ.
03 Forester XS 5MT
08 Outback 2.5i 5MT
Old Post 09-05-2007 06:37 PM
mikebike357 is offline Click Here to See the Profile for mikebike357 Click here to Send mikebike357 a Private Message Find more posts by mikebike357 Add mikebike357 to your buddy list Edit/Delete Message Reply w/Quote
aerosaaber
Paladin
put the jack right in the middle of that plate not on the part where it bolts - at least that's how I do it.
I never thought of the hockey puck, I was just gonna pony up and get a jack that had a rubber pad on it.
Old Post 09-06-2007 09:13 PM
The_Lizard
Yesterday was nice and warm so I finally did the front-to-rear tire rotation job I've been waiting for. I have only two jackstands made to straddle pinch welds, so I put those at the front. The rears are from my brother-in-law, they date back to the 1970s, and they just have simple saddles for tops. They would be perfect under a live rear axle. Usually in a situation like this I look for a place where a major suspension component attaches to the body, and this time I used the lateral arm attachment points.
Old Post 03-03-2008 12:49 PM
The_Lizard
Nice day, beer, start horsing around dreaming of extreme mods...
Old Post 03-03-2008 12:51 PM
orion747
Legionairre
Car: 09 Outback 3.0R w/ nav
Any chance these jack point are similar/same on the 05-09 models? I'm looking to put an jackstand at the pinch welds but am looking for somewhere to jackup the car Pictures would be awesome.
Thanks!
Old Post 05-10-2009 09:00 AM
orion747 is offline Click Here to See the Profile for orion747 Click here to Send orion747 a Private Message Find more posts by orion747 Add orion747 to your buddy list Edit/Delete Message Reply w/Quote
ron917
Paladin
Car: 07 2.5i
Yes, same place for jacks on '05-'09, according to the service manual.
Front: the plate in the center of the cross member.
Rear: the differential
Jack stands: on the rocker pinch welds indicated by the notches, same places the tire jack goes. You can also put them at a major suspension or cross member attachment point, just make sure they can't slip off.
Old Post 05-10-2009 02:54 PM
ron917 is offline Click Here to See the Profile for ron917 Click here to Send ron917 a Private Message Find more posts by ron917 Add ron917 to your buddy list Edit/Delete Message Reply w/Quote
CNY_Dave
Mengde's Brigadier
Car: 2003 LLBean H6 Outback
The rear diff moves a fair bit when lifting by it- worried me a little.
Dave
Old Post 05-11-2009 03:35 PM
CNY_Dave is offline Click Here to See the Profile for CNY_Dave Click here to Send CNY_Dave a Private Message Find more posts by CNY_Dave Add CNY_Dave to your buddy list Edit/Delete Message Reply w/Quote
ron917
Paladin
Car: 07 2.5i
quote:
Dave
It's mounted on rubber bushings, so it's going to move. But no worries, it is the official factory recommended rear jacking point.
Old Post 05-11-2009 04:46 PM
Paid Advertisements
Sponsored Ads
Also, check out these sponsored ads:
New Post Sponsored Ads
Rate This Post Edit/Delete Message Reply w/Quote
Show Printable Version | Email this Page | Subscribe to this Thread
Forum Jump:
Forum Rules:
HTML code is OFF
vB code is ON
Smilies are ON
[IMG] code is ON
Copyright 2007 Subaru Outback.org. All Rights Reserved.
Acura MDX   Honda Pilot   Nissan Murano   ResumePark
