Did they fix the old head gasket problem in the 2010+ model? New problems? Honda CRV? - Page 4 - Subaru Outback - Subaru Outback Forums
 1Likes
post #31 of 45 (permalink) Old 02-25-2015, 06:19 PM
airgas1998's Avatar
Car: 2016 Outback 2.5i Premium w/nav/eye
Thats not a HG leak sorry seen enough to say that your engine is exceptionally clean and you need to find better hobbies.
yeah..that's beyond lmfao.....
2012 Subie Outback 2.5i Premium Cvt,Ice Silver Metallic, All-Weather Pkg-SOLD
2016 OB Premium ISM with just about everything
airgas1998 is offline
post #32 of 45 (permalink) Old 05-16-2019, 10:49 AM
Angry
I have a 2010 Outback 3.6 with approximately 93,000km on it. I purchased the certified pre-owned from a Subaru dealer in the Greater Toronto Area in 2012 with approximately 27,000km. I loved the car then, still do. The car was running fine... until a couple of days ago. I was on my way home from work and some white smoke started coming from under the hood. I pulled over, popped the hood and noticed the inside of the engine bay was sprayed with coolant (greenish fluid). Didn't think it was a good sign, I checked the coolant reservoir and it looked creamy/milky...I thought it was odd, so turned off the engine for a few minutes. I wasn't far from my regular mechanic, probably less than 3km, so I thought I could drive it to his garage.
Started car again, drove about less than a km and noticed check engine light turned on as well as other indicator lights, I didn't notice the temperature gauge light up. Again, some white smoke started to come from under the hood, so I pulled over again and popped the hood. I looked under the car and found coolant leaking (green liquid) and a trail of liquid behind me as I was turning to pull over. I called CAA to get my car towed to my mechanic as I figured that I couldn't make the short distance. While waiting for the tow truck, the leak had slowed down and eventually stopped, checked the coolant reservoir and it still seemed full, but still had that milky look to it.
My regular go to mechanic (has his own shop) wasn't around, so another mechanic that shares the shop with him had an initial look and told me that there was oil mixed in with the coolant in the reservoir and found black "stuff" in the rad. He couldn't fully diagnose the issue because he had other cars to work on and suggest to wait until my mechanic returns from vacation.
I've been doing research for the last couple of days and I suspect it could be a head gasket issue, worst case scenario cracked engine block. I thought the issues with head gaskets were only happening to models before 2010 and specific to the 2.5l engines. I guess mine is the exception. I'm pretty upset, because I bought the car based on reliability and safety and was hoping to get at least 200k. I've recently got rid of my 2002 Mazda Protege 5 that had over 240k on it, didn't have major issues, but was a total rust bucket. I love Subaru but may be thinking twice about the next once. I realize that this could be possibly a big job or a complete write off, but I don't know what I don't know until my mechanic inspects the vehicle.
Based on the above symptoms, would anyone know what could be the issue and cost to fix (if it's worth fixing)?
gz212427 is offline
post #33 of 45 (permalink) Old 05-16-2019, 10:56 AM
no one wants you to have a bad head gasket
but, 95% chance you have a bad head gasket.
before this occurred, how often was the radiator examined for coolant level?
1 Lucky Texan is online now
post #34 of 45 (permalink) Old 05-16-2019, 11:06 AM
Sorry, don't know how often the rad was examined. Not sure if the above situation has to do with it, but last summer, I noticed that my AC wasn't as cold as it used to be. I didn't think much of it because it was toward the end of the summer and thought I could wait until the following year to recharge.
gz212427 is offline
post #35 of 45 (permalink) Old 05-16-2019, 11:21 AM
z28dug's Avatar
Agree with 1 Lucky Texan, my money would be on a head gasket.
Head gaskets can fail anytime on any year engine. Nothing magical about post '10 Subaru engines that they would be immune from failures.
"Happiness Is A Warm Gun", Beatles 1968
"The Rubber Banned Man",Spinners 1976
2011 SS Camaro
1984 Corvette
z28dug is online now
post #36 of 45 (permalink) Old 05-16-2019, 11:33 AM
If it is a HG issue, is it worth fixing and how long can I expect to keep the Outback? The fix is only as good as long as the mechanic knows what he's doing...
gz212427 is offline
post #37 of 45 (permalink) Old 05-16-2019, 11:58 AM
dropping in a used engine is likely your best option. not cheap. many folks would get JDM engine. You might also check car-part.com . Even craigslist - someone 'parting-out' a wreck....
has the mechanic fully diagnosed the issue yet? There are some 'edge conditions' like trans cooling coil bursting or ???? that might lead to blowing coolant out the reservoir and presence of 'oil' but - it's a 'classic' HG failure symptom.
post #38 of 45 (permalink) Old 05-16-2019, 12:58 PM
z28dug's Avatar
You car has relatively low miles. If the rest still in good shape, it might be worth the repair.
Should not be hard to find a Subaru specialist with more than a few head gasket jobs under his belt.
1 Lucky Texan likes this.
2011 SS Camaro
1984 Corvette
post #39 of 45 (permalink) Old 05-16-2019, 01:43 PM
^^^true - plus, if it didn't overheat severely, probably no bearing damage.
the 6 cylinders have some additional challenges for head gasket repairs but, having yours rebuilt might be better than my suggestion of a used engine, with possibly higher miles.
just have a discussion with your mechanic about your options.
post #40 of 45 (permalink) Old 05-16-2019, 03:02 PM
Thanks for the advice folks. My mechanic's only back on Tuesday, so it's still a waiting game. I'm curious to see what my mechanic's findings are, he's not Subaru specialist, but has worked on my cars and has been reliable so far. We'll see what he says...hoping for the best, expecting the worst.
gz212427 is offline
